I have got PL117-D Turntable and CT 2OO Tapedeck.Both needs new belt.Where is it possible to get there?Can you help me?Thank you.
  • 1,202 Answers
Hi u can buy a turntable belt of E/BAY £5.99 recycling-electonics,..,.Radio shack TANDY used to sell an assortment Pack of belts for tape decks etc also u can try (UK Vintage Radio) for the tape deck belts.,..Good luck
I have a Crosley 3 in 1 turntable (not sure of the model but I'll include a photo). The turntable spins fine if it hasn't been in use for a while. But after I start to play a record, the turntable will...
Crosley Turntable Belt Replacement Video from Crosley Radio on Vimeo
Yes. Please contact Crosley Radio at 1-866-CROSLEY for assistance on replacement parts.
It sounds like the turntable belt has stretched . Replqacemnet belt can be purchased from Crosley. The number is above.
Jun 02, 2014 | Audio Players & Recorders
Turntable has stopped working, possible belt stretch
I don't think it's likely that the motor is in trouble just by having the belt wrong. It would require more physical damage to cause the motor to play up. Having said that the motor could have been in trouble before you touched the belt. But you do need a new belt, all you need to do is measure the diameter of the belt in mm. You might also need to measure the width. To find a new belt put the words "turntable drive belt XXmm" into Google. You can add Crosley to the start, but many belts are universal. Your measurements don't need to be spot on with the diameter, so if you have measured it at say 95mm, a 90mm to 100mm belt will do the job. However fitting the new belt is a different matter. You need to know the correct way, or the speed might be wrong. I can't help you with the fitting of it, so you will need to check how to do it. Some makes have YouTube videos of the fitting. I would just look for Crosley and see if any look like your model.
If fitted correctly and there's a problem with speed still, then you should look more closely at the motor.
Mar 26, 2014 | Crosley Stack-O-Matic CR40 Turntable
Turntable belt keeps falling off.
Hello, How old is the belt? It is possible that you might need a new belt. Just like a rubberband, it can stretch and with age, it starts losing it's elasticity. If that's the case, then the belt would fall off.
I would check with the manufacture to see if they have replacement belts. They can't be that expensive and it would be worth a try.
Hope this helps.
Best wishes.
Mac =)
Mar 12, 2014 | Crosley CR248 Turntable
Prolectrix usb turntable
Getting drive belts is easy, fitting them is the problem. If it is still attached in any way make a note or a photo of how it is fixed. This will help to putting a new one on. Measure the diameter of the old belt in mm. You will also need to measure the thickness in mm too. Then put these words into Google: "Turntable Belt xx mm" (use the diameter measurement in place of the XX). Then search the results looking for something that is very close to your belt. If you find the belt, try searching again for the fitting of it. Quote the model number of the turntable. The fitting instructions might even be found on this site.
Feb 27, 2014 | Audio Players & Recorders
I have two problems. One: Does the Kenwood KD34R Turntable does it need a system cord? Two: I have a Kenwood KD491/492F turntable, it drags. It has a new belt. Please help. Thank you.
just had that problem when i replaced my belt on a pioneer pl600 turns out there was residue from the old belt on the drive pulley making the belt ride on the edge of the pulley instead of in the groove there is also two adjuster screws under the turntable that u took off to replace the belt with these u can adjust the speed manually was told that by a repair person from vintage electronics great place online for help
Sep 29, 2013 | Kenwood Audio Players & Recorders
Do I connect my Cassette deck player to the "Switched" or "Unswitched" plug at back of Radio? please help. Radio is a Sansui Model 210SS and tapedeck a Pioneer model CT-F2121.
It can be plugged into either one. Just remember that the deck will only power up with the radio on if it is plugged into the switched jack.
Aug 12, 2013 | Audio Players & Recorders
Cannot hook up sound to surround sound , everything else works, cd player, radio, tapedeck. just the turntable does not work. any suggestions? deb
Hi, you need to connect the turntable to your amp via a phono input connection. If no phono input available then a pre amp needs to be used between turntable and amp to up the signal. Cheers John. Styluscity@gmail.com
Sep 28, 2011 | Technics SL-1200MK2 Turntable
Lg lrm 1250
Looks this model's turntable support has a coupler shaft built-in which is supposed to go down into the turntable motor hole and make contact with the turntable shaft. Is that right in your case?
So I would wonder if the turntable support has gotten bent due to heat. That's common on some models.
When you take it out and look at it from the side, are the legs straight and perpendicular to the shaft or are they bent down?
On some models, you can heat them over a stove flame, then put them on a flat surface with a weight to old them in position while they cool.
Otherwise, you'll need a new turntable support. LG / Goldstar calls this a "rotating ring".
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | LG LRM1250 Microwave Oven
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
43 people viewed this question
 Grubhead
Grubhead
