Question about HP LaserJet 5000 Printer
50.4 fuser error
My hp 5000 ps laser printer has problem 50.1 fuser error & 50.4 error
how to solve this
  • NinaE May 11, 2010
    Just wanted to add/correct: typically not a user-serviceable part, but if you are comfortable, give it a try. Otherwise, have it serviced.
    President:
  • 3,278 Answers
Some suggestions:
  • Turn the printer off for 20 minutes and allow the fuser to cool (this may resolve high temperature fuser errors).
  • Re-seat the cooled fuser assembly (this may resolve other non-temperature related fuser errors).
  • If the printer is plugged into a power strip or surge protector, plug it directly into a wall socket or different circuit (this may resolve errors caused by an inadequate supply of electricity).
  • Try a different power cord (the current power cord may be damaged).
If still a problem, your fuser is faulty and needs to be replaced (typically not a user-serviceable item) by service. Hope this helps.
Posted on Jul 21, 2009
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
What is fuser error 50.0 in hp laserjet P1102
50.0 can mean either the fuser has suffered an unrecoverable failure or, the power supply is failing. 95% of the time, it is the fuser that is failing. A rebuilt fuser is more economical and their are very good companies that do just that. The best I have seen that is certified by Hewlett-Packard is PARTS NOW!. They are located in Middleton Wisconsin and they are very reputable. I would check out their website: Laser Printer Parts HP Lexmark Canon Ricoh Parts Now
I have personally been trained on several models of color & black & White HP printers at their facility.I have seen their factory floor where they refurbish the printers and their components.
Best of luck to you.
Apr 04, 2016 | HP Laserjet Pro P1102 Printer Laserjet 600...
50.1fuser erro hp5550dn
50.1 Fuser error:Low/No Fuser tempatrature, replace Fuser assembly.
For service engineers: Reason: thermo switch open, remove fuser assembly, dis-assemble up sleeve, check switch continuity, if no continuity, remove switch & just hit gently on aluminum capsule till continuity comes,make sure it should not damage or dent,once continuity comes, clean main thermister & sub thermister, fix it back, power on the printer, chek errors,adjust fuser temperature in low, give prints up to 50 blank copies, chk.. if problem repeated replace Fuser assembly, but success rate is 70% for above exercise. Note: Only professionals can perform this activity..
Thermo switch:
Oct 02, 2013 | HP LaserJet 5550 Printer
When I initiate a print job on my HP P3005 laser printer it makes a roaring sound and then I get a error 52. I have read its the fuser and then I read its the laser scanner. Which one is it? Tom
Error 50.x related to fuser &52 for laser scanner assm.
For tec guys only: Open laser scanner assembly, remove laser scanner motor rotor, lubricate the shaft fix it back. (dont do this job with bare hands) check best of luck
Sep 21, 2011 | HP LaserJet P3005 Printer
49.2F9D ERROR POWER OFF THEN ON
Hello, the dreaded 49.2F9D Error Turn Power On/Off.
There have been many reports of this error in the HP P3005 Laser Printer. This is a generic fatal error, the root cause is undetermined. It could be related to an application "corrupt data" or faulty printer firmware, or the formatter board, or reports of the fuser causing this problem. The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Does the error still report? If NO then an application may be causing, try to isolate the file causing the problem. If YES then Firmware/Formatter/Fuser is likely the problem. A new firmware file can be found here.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=ca&prodNameId=1846102&prodTypeId=18972&prodSeriesId=1846088&swLang=8&taskId=135&swEnvOID=54
Does the error persist after the firmware application? NO problem solved YES? Formatter/Fuser.
Contact a local HP Authorized Service Center for further assistance.
Dec 23, 2010 | HP LaserJet P3005 Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
May 30, 2008 | HP LaserJet 8150n Printer
Printer
You need to replace the fuser, here is an example of replacement part
HP Fuser for LaserJet 5000
These are instructions for replacement:
HP laserjet 5000 fuser instructions
Apr 24, 2008 | HP LaserJet 5000 Printer
HP LaserJet 5000 Printer Logo
1,010 people viewed this question
Seeker5211
Seeker5211
