Question about Canon Cameras
Just bought canon 7d .mk11 I am battling with the setting the right exposures in Manuel mode please heel
  • Canon Expert
  • 488 Answers
The setting used in manual mode are dependent on the light source and the type of photography i.e. do you need a fast shutter speed or not. Or are you doing portraits etc. The settings used will also be different for the different type of lenses you use. If you are using a kit lens (eg 18-55mm) and you are shooting indoors try as a start f5.6 - 1/60 - ISO 200 then adjust it to suit depending on the results. The majority of photographers use the Av mode set to f5.6 to f8 at 100-200 ISO then adjusted so that the shutter speed is equalish to the focal distance i.e at 55mm ensure about 1/60 as a minimum to avoid camera shake.
Posted on Jan 04, 2017
  • Canon Master
  • 5,412 Answers
Is this information not contained in the manual ? If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
I bought the new Tamron 20-200 lens and after trying it on my Canon 7D non of my lenses will focus on that camera. What has happened?
Sure you did not switch to manual focus while testing the Tamron? Sure all settings are correct?
If the Tamron still auto focusses on you 7D, check the forums about this. I know Nikon sometimes messes up the firmware, when a non Nikon lens is used, but not on all camera's. And not with every firmware.
I don't know the 7D enough to check more details, but check everything about the AF settings. I can't imagine your lens did something wrong with the camera.
Jan 07, 2015 | Canon Cameras
I bought a kit with a Canon EF 75-300 f/4-5.6 lens with a Vivitar Series 1 2XMC4 AF teleconverter. I have a Canon 6D. The camera reads F00 when hooked up and says there is no lens attached.
The teleconverter lacks the electronics to communicate with the camera, or to let the lens communicate with the camera. You have to use the manual exposure mode and set the exposure yourself.
Feb 12, 2014 | Canon Cameras
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
Feb 02, 2012 | Canon Cameras
I have a new 580EXII mounted to my Canon 7D. I do not seem to getting the "double flash" (not sure what the technical term is) that I expect and pictures are coming out dark. I'm think...
Holly, I believe you are referring to the pre flash for the ETTL function. both flashes happen so so fast that it looks like one flash. If your pictures seem dark make sure your flash is set to ETTL (press the MODE button unlit ETTL is displayed) this way the flash output is automatic. If it is still too dark you can change the flash output by adjusting the FEL (flash exposure composition) by pressing the button in the center of the dial until +/- is displayed the turn the wheel to select a + exposure (you can adjust this in 1/3 stop increments) then press the center button again. This can be found on pg 14 of the manual
Hope this helps.
May 24, 2011 | Canon Speedlite 580EX II (1946B002)
White balance issues on canon rebel xs
Its exposure problem you need to take canon service center and tell them to adjust exposure and shutter speed.
Jul 31, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I cant change the apeture value in manual mode. all other modes are working properly. i tried removing the batteries and the lens and no change.
the exposure lock function is enabled. its to the right of your lcd screen bellow your scroll wheel. the LOCK switch
May 17, 2010 | Canon EOS 7D Digital Camera
400D manual mode
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
Dec 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Manual shooting mode problem.
The exposure compensation dial (at the back) doesn't work when you're in Manual. In Manual, you set the shutter speed and aperture to get an image with the amount of over- or under-exposure you need. In the view finder, the "exposure meter" at the bottom shows how much light there is where the lens is pointed. When it shows what you called "2-stops", its really underexposed. Thus your black images. You need to increase ISO, open the aperture and slow down the shutter speed (or a combination of these 3 options)
Set your camera to P or full-auto. Do the photos turn out ok? If they do, then there's nothing wrong with your camera and you just need practise on the Manual mode.
Aug 13, 2008 | Canon EOS 40D Digital Camera
Canon remote RC-1
In order for the remote to work the drive mode needs to be set to "self timer-remote" .....that is selected by the drive mode selection button identified with the clock and multiple frames symbol ....on the back of the the right of the lcd monitor
May 20, 2008 | Canon RC-1 Remote Control
Canon Powershot S330 Picture Brightness Help!!!
It sounds like the camera exposure system is out of whack and may need to be serviced. You may want to ensure that exposure compensation is set to 0. Check one of your overexposed images with the display in the 'Detailed Display' mode (two lines of information at the bottom of the LCD). If the second item on the top line is not ±0, the exposure compensation is not at its default value. To set, put the camera in M(anual) shooting mode. Press the Exposure/White Balance button until you see a scale along the bottom of the LCD from -2 to +2. Use the left or right button to set it at 0. If the value is already at 0, you will probably need service.
Apr 28, 2008 | Canon PowerShot S330 / IXUS 330 Digital...
Cameras Logo
371 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
