Question about Car Audio & Video
When my kd-db42 car radio is on fm & my ks-bta100 bluetooth and my phone's bluetooth is on, does not then play through speakers i have to change the source to Faux before i hear on the speakers
mixmaster
  • 626 Answers
SOURCE: Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Posted on Sep 14, 2007
SOURCE: Hearing Zune
The contact where the Zune plugs in was loose.
Posted on Jul 24, 2008
HitWizard
  • 67 Answers
SOURCE: how to program bluetooth phone to sony radio cd player
Ok, I have a Sony MEX BT 2600. To pair my phone to the radio, I had to press and hold the BT button for 5 seconds until it flashes, then I have to search for devices on my phone. Xplod comes up. When it does, pair the two and use code 0000. That should do it. Also make sure the BT icon is showing, meaning it is activated for the Sony to connect. When conncted, the radio should show a phone icon for the BT Phone segment of the radio, and then another icon for the BT Audio, both should what looks like radio waves coming off of them, meaning the two devices are connected and recognizing each other.
Posted on Jan 30, 2009
SOURCE: I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Posted on Sep 18, 2009
SOURCE: blackberry bold 9000 speakerphone doesn't work!
Guys- I have had the same problem with my speaker not working and it comes down to the spacing inside the phone. Some people have resolved the problem by placing a small piece of paper or credit card between the phone or the battery back. I actually took the back cover off, the battery off, and then unscrewed the 6 tiny screws to take the back of the phone off. You'll then see two small pins that act as spacers to keep the phone back off of the speaker and you can gently bend them upward a bit more and this totally worked for me. I noticed after I was using a leather pouch to hold the phone, the only way to take it out was the pinch the phone on that area, and was thus "smooshing" these pins down and not giving the speaker the appropriate spacing. You'll void your warranty by doing so - but you should be able to fix the problem.
Posted on May 16, 2010
What is bluetooth adaptor for jvc kd s28
According to the installation manual for the KD-S28, the bluetooth adapter is KS-BTA100. You can find this on page 2 of the installation manual which is available from JVC's support page: http://books.jvc.com/ . Enter the model number and click the Model Search button. The direct link to the installation manual is http://books.jvc.com/Download/119824748/GET0754-002A.pdf .
I hope this helps. Amazon has a couple of the adapters for sale: https://www.amazon.com/JVC-KSBTA100-Add-On-Bluetooth-Adapter/dp/B004REMUJE . Other vendors do not report having this in stock.
Mar 27, 2017 | JVC Car Audio & Video
How can I make it blue tooth
http://www.manualslib.com/manual/450459/Jvc-Kd-R530.html?page=10#manual
According to the above link for the manual, you require a KS-BTA100 adapter that plugs into the rear of the unit
Hope that helps
Oct 05, 2015 | JVC KD-R530 In Dash Stereo
I have a JVC KD-S29 RADIO AND I AM TRYING TO GET THE BLUETOOTH TO PAIR WITH MY PHONE AND I CAN'T GET IT
It is not bluetooth ready. Not sure you can use the BT adaptor KS-BTA100. Will let you know tomorrow.
Feb 22, 2015 | JVC Car Audio & Video
Turn on the Bluetooth on the ke-s39
It needs a blue tooth adapter KS-BTA100
Dec 30, 2014 | JVC Car Audio & Video
Proper color for jvc 320 to jvc ks-bta100 hookup
There are only 3 POWER cables to worry about and one 3.5 aux. BLACK, BLUE, AND BROWN. Tap existing connections. on back of harness and connect 3.5 aux to back on unit.
Feb 14, 2014 | JVC KD-S5050 CD Player
Jvc car radio won't mute on incoming calls
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
Dec 08, 2013 | JVC Ks-bta100 Bluetooth Adapter For Select...
JVC KD-R330 Won't turn off Demo mode - tried instructions. Every time I follow the instructions (Turn on, Hold Menu, push "vol" button, change to Demo off...etc) It doesn't work. In fact, as soon as I...
Do you have a Bluetooth adapter plugged into the KD-R330?
A compatible Bluetooth adapter (like the KS-BTA100) usually plugs into the rear auxiliary port of the receiver. It then needs to be "paired" with your Bluetooth device, for example, a Bluetooth phone headset.
What you're describing sounds like what can when no Bluetooth device has been "paired" yet.
If you don't HAVE a Bluetooth adapter connected to your KD-R330....is it possible you accidentally plugged something into its rear auxiliary jack? Or the front auxiliary? In other words, is it possible your KD-R330 receiver is mistaking some other device for a Bluetooth adapter?
Don't know if that helps at all...if there's no adapter issue, and nothing connected to the AUX jacks, probably your next step should be a call to JVC, or whatever number you were given for tech support.
On the bright side, since the receiver turns on, and responds to some commands, you probably didn't mess up anything major in the wiring. And, there's also the possibility the receiver is defective....certainly if this continues, and JVC can't help you, trying a replacement might be worth a try.
BTW, feel free to post a reply...I'm going to look further to see if there's any other documented issue besides an adapter that might cause the problem you're having.
Oct 29, 2013 | JVC Car Audio & Video
Using an external mp3 player on my JVC KD-LX111
You could try using an FM transmitter which plugs into the earphone jack on your Mp3 player, then all you have to do is tune the radio to pick up the transmitters frequency.
Nov 13, 2007 | JVC KD-LX111 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
