Question about Fender Music
My Boss Loop Station RC-3 won't work on auto because my Boss Suppressor NS-2 cuts the volume. I've tried different positions in the pedal chain.
Fender Telecaster, RC-3 NS-2, into Boss Blues Cube Hot
2 Suggested Answers
  • 5603 Answers
SOURCE: Hello - I have a
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
Posted on Jul 20, 2011
When i plug the cable in my boss rc-20 it turns on and instantly it turns off, how can i fix that?
I would suggest cleaning the input jack, and if that doesn't fix it, replacing the jack.
Apr 22, 2016 | Roland Boss RC-20XL Loop Station Twin...
My RC-50 suddenly won't power on.
Has the unit ever had another ac adapter plugged into it?
Mar 04, 2013 | Boss Rc 50
Hello - I have a Boss RC-2 Loop Station. While I enjoy the pedal's capabilities, it almost always creates an unwanted hum and sometimes an electronic pulse in every amp I use it with. (I typically keep...
Jul 20, 2011 | Roland Boss RC-2 Loop Station Stompbox...
Volume knob is broen
The obvious answer is to have it repaired. Sometimes the parts can be hard to find but either DigiKey.com would have the part or you can go to Roland/Boss and order the part. If the knob itself was smashed, the pot also is likely damaged. $5 of parts should fix it up. If you are adept at electronic repair it should be an easy fix.
Jun 17, 2011 | Roland Boss RC-2 Loop Station Stompbox...
I have the Roland Boss Rc-20xl Loop Station, and I'm running off of batteries I have been since I got the pedal. In the middle of recording a phrase the pedal shut off and started resetting itself...
Hello!
I am not positive on this but I would try to clear all of the loops. Try holding the right pedal for about 5 seconds.
If that does not work, hold the right pedal for about seconds while you turn off the unit. Release the right pedal then turn the unit back on.
Hope that helps!
May 11, 2011 | Roland Boss RC20XL Phrase Recorder Pedal
The Auto on my Boss RC2 sometimes doesn't seem to pick up a signal and engage. It is plugged into a multi- socket adapter and I do not have the amp turned up too loud as the room is tiny. I thought it was...
Sometimes, with BOSS pedals, the battery must be disconnected before using another power source. I ran into the same problem with my DS-1 distortion. If it's not that, then check the power rating of the power adapter. It should read, for the output, exactly 9V DC. If it doesn't, then you have to get a power adapter that has that same rating. Boss pedals will not use anything other than 9V DC (I know, I've tried).
Hope that helps!
Mar 26, 2011 | Roland Boss RC-2 Loop Station Stompbox...
When I turn on my BOSS RC-20XL Loop Station the reverse, tap tempo, write, exit and one shot phase start to blink rapidly and I cannot get them back to normal. Therefore, I am unable to use my loop...
Hi. I had the same problem and fixed it by clearing all the phrases. An explanation of how to do this is below (written by someone else, not me) But, expect your guide beat to now sound like a fuzz instead of a drum. This really sucks and there is apparantly no fix for the guide sound except to send it back to Boss. Good luck.
1. Start by selecting Phrase 1.
(if the 'REVERSE' or 'AUTO START' are lit press them off.)
2. Select 'INST & MIC' by pressing 'MODE'
3. Hold down 'EXIT' and 'AUTO START' together - at the same time, this should light up the green LED for 'LOOP PHASE'
4. Hold down 'WRITE' and 'EXIT' together
then hold 'WRITE' on its own
then 'WRITE' and 'EXIT' together again...as if you were clearing a phrase.
they should light up in red and flash, if not try a combo of section 4.
5. Repeat on all Phrases 1 - 11.
Mar 24, 2011 | Roland BOSS RC-20XL Loop Station Phrase...
My Boss RC-2 Pedal is having a problem with the output. With the volume turned up to max, the signal is suddenly extremely faint on can only be heard if there is silence in the room. Even the backing track...
Most PROBABLE is the output jack either has been broken (common due to mishandling and accidents with cables such as stepping on the plug while plugged into the pedal) or the soldering of the jack in the pedal has broken loose. Less common is a circuit board crack in the vicinity of the jack. Open pedal and inspect for the above suggestions.
Mar 11, 2011 | Roland Boss RC-2 Loop Station Stompbox...
I have NS-2 Noise Suppressor Pedal, this works fine but in some moment make a radio noise (hum) and the output signal comes down (like turns the volume to 0) ... I don't know what it is, I'm going to...
The probable problem is poor connections at the input and/or audio output jacks.
Usually the power supply will fail either on or off which is sometimes cause by a bad input power jack.
In any case, the problem is likely internal and will require repair.
Aug 06, 2010 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Music Logo
20 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
