Question about Bose Audio Players & Recorders
Have you any fuses for the bose 402 speaker please
    Master:
  • 469 Answers
There are some Mom and Pop electrical stores in every town.. Im betting they could help you alot more than auto store :) Mouse Pads Choosing The Best Pad For Your Computing Needs AmanStino
Posted on Jan 04, 2017
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Definitely the easiest way to find the right fuse, is what Bill said, take out the (assuming that is the problem, are you sure theres not a reset switch? not plugged into a dead outlet? made sure all power cords are plugged in tight and not lose?) and take the fuse to a local electrical store, NOT best buy! There are some Mom and Pop electrical stores in every town.. Im betting they could help you alot more than auto store :)
    Top Expert:
  • Bose Master
  • 40,798 Answers
No
fixya site doesn't do spares for anything
go to an electronic shop( jaycar or the like )with the old fuse and they will help you out
Blown Fuse and Need to replace
For technical help Call Bose.:
1-800-380-4831
Mon. - Fri., 8:30 AM - 9 PM ET
Sat., 9 AM - 6 PM
If you're not in North America see this site:
http://worldwide.bose.com/productsupport/en_us/web/home/page.html
Jun 14, 2015 | Bose Companion 3 Series II Multimedia...
To Mr. Hyde: you appear experienced with Bose 501 Series III speakers. I need to replace a burned out glass bulb fuse inside the right speaker, the fuse for the woofer I believe. I think that you said that...
Hello whit_hughes,
Just received your request for some information regarding Bose 501's......... Series III. Your looking for te manufacturers part # for the fuse which is in line with the woofer? The fuses used ON the Series III Crossovers (hard wired/soldered directly to crossover board/componants) have been Identified as BUSS #2494, 2amp, Quick-Blow Glass Tube Type Fuses. The fuse which is in-series with the woofer & the fuse which is in-series with the pair of tweeters are the same! In theory this means that the woofer is capable of twice the wattage of the tweeters due to the tweeters being wired in series with each other..... which in turn divides the power beween the two equaly. On the woofer circuit there is only the one speaker or voice coil obsorbing the power. The woofer circuit being wired in parallel with the tweeter circuit again splits the power between the two cuircuits..... so in an ideal situation the woofer sees 50% total input power while the tweeters each see 25% total input power;;;; totaling 100% total. The way Bose has fused them in the Series III's is such that each branch can obsorb a total of 2 amps before shutting down each indivigual branch. This can be adventageous..... should peak power be exceeded causing loss of full load abruptly, Amplifier Power Output Transistors usually blow..... however when only half of the full cuircuit shuts down due to peak power exeeding limits causing one fuse to open (blow) ... the actual impedance (resistance) of the speaker increases protecting the Amplifiers Output Transistors! Thats the reason for the 2 fuses. Each of them are identical. They are soldered into place.... via the wire which is attached to each end of the fuse. (Note; the fuse "kit" Bose is trying to sell you is an external in line fuse holder for each speaker {costing 1.29 each} & 2 fuses for each holder, One for now & One for Later aftr it blows {costing 1.00 each}..... costing Bose 6.58, neting Bose $13.42 Profit!!!! Keep in mind that this fuse WILL NOT FIX YOUR PROBLEM EITHER! DUE TO THE FUSE WHICH IS PRESENTLY BLOWN HAS NOT BEEN REPLACED!!!!! ) The one that has to be replaced is on the crossover... not between the Amplifier & the Speaker Enclosure. Tools required = 1 Long Big Straight Blade Screwdriver to pry off speaker grill, 1 Phyllips Screwdriver to remove screws seccuring woofer to encloser... be carefull not to damage/tear gasket, 1 pair side cutters to cut blown fuse out of crossover curcuit, 1 pair needle nose pliers to attach NEW fuse to crossover curcuit, 1 soldering Iron & a small piece of solder to re-solder fuses leads securly to crossover curcuit. ( replace gasket, woofer, screws, & speaker grill. ENJOY! Should additionaL informaton be required please let me know.... you'll have to leave me your e-mail address for pictures or drawings.... as I don't think they can be sent through this site. Hope this helps ya..... Its an EASY JOB...... you CAN DO IT! & will be glad you did when your done, they'll sound GREAT! ) GOOD LUCK!
Jun 22, 2011 | Audio Players & Recorders
Left and right speakers are plugged in. Left speaker works fine, right speaker is on but no noise. please help! 408.722.6236
This is a clear indication that the right speaker has got a blown fuse, You need to call this number to get it opened or replaced. Call 1-800-WWW-BOSE (1-800-999 2673).
Thanks
Oct 31, 2010 | Bose 3 2 1 GSX System
My left side speaker is not working i suspect fuse blown but where is the fusebox situated on my BOSE 901series III.
There is no fuse in a 901. Have you swapped channels, speakers, bypassed the EQ to ensure it or its pathing has no part in the failure?
Oct 28, 2010 | Bose 901 VI Main / Stereo Speaker
One of the speaker ports does not work, only left and center works but not right, does the base have a fuse box?
Please check if the cable connecting the speaker port to the speaker is OK. To check this, connect this cable to any other port and see if the speaker is working. If so then the internal connection has to be set right by a technician from the BOSE company as they have the necessary tools to open the Base. Yes, the base has a safety fuse to save the system from spikes.
Dec 20, 2009 | Bose (321GS) System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Oct 08, 2008 | Bose 151 Main / Stereo Speaker
48 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
