Trying to find seven two on my tv - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 45,653 Answers
Get the onscreen menu up and then select auto tune
let the system find and fix the station on the channels selection
  • 5,574 Answers
This is an Australian free channel and depending on the receiver you are using it will be on either:
channel 62, 66, 72 or 137
Windows 7 drivers
They should have a windows 7 driver. I suggest that you contact Viewcast Tech support.
David
Apr 11, 2013 | ViewCast Osprey 210 Video Capture
My new Panasonic Viera TH-P42X20A Plasma TV was on and the picture disappeared. A red light is flashing seven times and then stops and then flashes seven times again. What does this mean? I can't turn...
Tries tv unplug,replug it back like about an hour later.Now the tv it is resetting itself back to the factory setting.The tv should be working again.If the problems,still have the same result.The power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.If this a new tv,still underwarrenty,call Panasonic for the service.Tv is new just recently bought?Take it back were u bought it and exchange it for a new tv.
Apr 03, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Sony WEGA KV-40XBR800 Standby light blinks seven times when trying to power on, will not turn on
there is a problem on the power supply section of your tv.try to check the regulators horizontal output,and bad capacitors.
Jun 14, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
I have no picture and the timer/standby indicator flashes seven times. i cant find a list of the codes on the internet for what that flashing light means
seven blinks is over current protect try to turn the tv on using the sony original remote with this button sequence press display 5 volume up then power if the tv comes on replace ic8002 on the power supply if it doesn't I would still try that fix very common on sony tv's
Jan 24, 2010 | Sony KP-48S70 48" Rear Projection...
Standby blight bliks for seven time tv wont turn on
Seven blink indicates that there is a high voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hopw this helps .
Jan 23, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Need driver windows seven
Go this website www.driverguide.com they usually keep up with the current drivers.
Dec 13, 2009 | KWorld KW-TV878RF PRO (kwtv878rfpro) TV...
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega tv blinks seven times and does not come on
seven blinks means high voltage shutdown it gone into safety mode you need to check power supply regulation and horizontal circuits
shaun
Jan 16, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
