I have a space of about 50 sq. ft, whether i should go for Plaster boarding? Can anyone suggest a good service provider in Bristol?
    New Friend:
    Problem Solver:
  • 6 Answers
Going for an plaster boarding can be a good option to provide you with the best option that is helpful in providing you with the best options. One can get good options for providing one with the best way out to provide one to help with many options. If you are looking for getting good options for providing you with the best options for you from Plasterer Bristol
Area in Sq. Ft. of Hexagon of 50 ft length side
If you have six sides, all 50 ft in length the answer is 6495 sq. ft.
Feb 19, 2018 | Heating & Cooling
I am trying to figure out the square footage for siding on my house the front and back are 50ft long by 8 ft high. the sides are 30ft by 8 and then the peaks
50 X 8 = 400 multiply that by 2 ( front plus back) = 800 sq ft
sides 30 X 8 = 240 again by 2 for both sides = 480 sq ft
add both sums = 1280 sq ft
now to work out the triangle areas for the peeks you have to provide the vertical heights of the peaks and use the formula for areas of triangles (1/2 base by height) to get the rest
however you have not considered on the window/doors areas that could be used in the apex areas
you have a basic area but you are advised now to get quotes from cladding companies who can calculate it to close area to save wastage
Aug 01, 2017 | Heating & Cooling
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
Not cooling room
Assuming the unit is 'cooling' but not cooling it 'well,' I would think the unit is too small.
NOTE: 2000 Btu for every 100 sq ft of cooling space if the room is well insulated. If not - then 2000 btu for every 66 sq ft.
For example - a 12000 btu AC unit should cool 600 sq feet of cooling space if well insulated.
or
400 sq feet if not well insulated.
hope this has helped.
Aug 05, 2011 | Danby DPAC12031 Air Conditioner
I need spreader setting to do 2.3 pounds per 1000 sq ft
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
We do have a general rule, called the 50 by 20 rule which will allow you to use any product in any spreader, but there is some work that will need to be done.
* Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (In your case 2.3 pounds)
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less. In your case i would suggest about 2.75 or 3)
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, you will need to increase the setting accordingly
* If they you up short, you will need to decrease the setting.
Feb 17, 2011 | Scotts Company Scotts Lawns Edgeguard...
Not a problem, just a question. Can you determine from the Model #, 5018QKA1, what size unit I have? Style # is 18MC 000087CR. Thanks.
It is a 18,000 btu unit which is good for 700 to 1000 sq ft of living space. Model# 50*18*QKA1< the 18 stands for 18,000 btu. Hope this helps!
Aug 31, 2010 | Kenmore Heating & Cooling
How much area can 1hp of this brand can cool
the 'rule of thumb' is 1 ton of AC for every 600 sq feet of a well insulated space (400 sq ft if not well insulated)- for example if the space to be cooled is 1200 sq ft - and is well insulated - you would require a 2 HP unit. 1200 divided by 600 = 2
if the space was not well insulated - you would require a 3 HP unit. 1200 divided by 400 = 3
note; 1 ton of air conditioning - is sometimes referred to as 1 HP or 12000 Btu. Whether you call it 1 HP or 1 Ton or 12000 Btu - they all three mean exactly the same thing.
take this example - 2 tons of air conditioning can also be referred to as 2 HP or 24000 Btu.
fyi - it doesn't matter what 'brand' - they all work off the same principle.
hope this helps
Jun 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Jul 21, 2009 | Ruud UBHC Air Conditioner
Manual J Calculations for Residential house 1018 sq. ft. American Standard unit
without actually doing a load calc it would just be an educated guess.Good choice in equipment though.
Aug 06, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
