Question about Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive
Can't mount my external Iomega harddisk anymore
My Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive hard drive started to be hesitant when I turned it on, Time machine backups fail and, for some months now, it won't be recognized / mounted anymore. Specs: I have a full optional 24 inch iMac Intel core 2 duo at 2.8 GHz processor speed / Mac OS system 10.5.7
As it consists of important data, which I desperately need for a project I really want to retrieve my data. Can’t find any Iomega support in Holland, and Apple store where I bought it can’t help me either. Anybody???
tnx, Hjarald
    Scholar:
  • 97 Answers
Try running disk utility. If it can see the hard disk but it isn't mounting it, try clicking "repair" or if that is greyed out, "verify" then "repair". Be warned that this could take a very long time, so leave it over night. It may even look like it has crashed. This may either fix the problem, or tell you that the drive can't be repaired (in the data sense) and it will hopefully mount it read-only so you can retrieve the data. You will need another drive with enough space to copy everything off. If copying data fails, try copying folder by folder or even file by file to get off all files that are ok, as otherwise it will just give up when it finds corrupt data.
If disk utility cannot see the hard disk at all, try the other interfaces (usb/firewire/sata). If it can't see it in any of them, try it on another computer. If none of them can read it then the unit is dead. You may be able to retrieve your data by taking the unit apart, removing the hard disk, and placing it in another enclosure. This will probably void your guarantee though, so it's a choice you may have to make :(
Posted on Oct 27, 2009
  • 44 Answers
Did your computer has installed all driver that requires..?
Posted on Jul 21, 2009
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Iomega Ultramax red light turns on at start.
It's probably the power supply. Iomega has been having lots of power cord failures. I had same problems and thought it was the drives until I did a internet search and saw lots of people having the same trouble. I called Iomega and they sent me a new cord. Problem fixed. It's the little black box that dies...
Apr 04, 2012 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
My wife and I bought an Apple mac computer just over 3 years ago, and as we wanted to store our large collection of CDs on i-Tunes on an external hard-drive and not on the Mac computer drive, we bought an...
no --there are no engineers at fixya site
from your description the aux hard drive has failed
Most hard drives using discs are good for around 3 years max and then the bushes and bearings fail
If that is the case then you will have to find a repair shop that has the capability to remove the disc from the hard drive and recover all that you have saved
if it as what I have suggested then consider this
There are hard drives (SSHD) on the market that use solid state technology and do not have spinning discs that fail over time
The cost is around $60.00 per gig of storage
best if you take it to a computer repair shop for a proper diagnosis and while there discuss the SSHD technology to prevent failures in future
Feb 27, 2017 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
I have an Iomega UltraMax 1TB Triple Interface External Hard Drive and have been told that the case/enclosure is dead, but that the hard discs inside are fine. Would it be easy to put them in a new case?...
It depends on the physical size of the drive.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=92&name=External-Enclosures
On the left there is a size filter. Pick one of those that suits your use.
Mar 21, 2011 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
When I switch the drive on it 'ticks' but won't properly turn on for a long time — up to an hour. As I write this the drive has been ticking for over two hours and has still not booted up.
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered suction vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free it up
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps good luck
Sep 14, 2010 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
I've been using two of these drives for a few years.last week one of them stopped connecting to my iMac (10.6.1). Today the second one did the same. I turn on, get a white light, hear clicking in the...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Oct 03, 2009 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Ticking noise
Ticking noises are indicative of major hardware failures. As no HDD manufacturer actually warranties data, if you have important files on it your drive, you will likely need the help of a pro.
If you have all your data backed up elsewhere(including on the Mac), contact Iomega and have it replaced under warranty.
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/cci/product.php
If you do need files recovered, let me know as well as your region and I will recommend a good location.
Chris
May 22, 2009 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
UltraMax 650GB
I would remove the drive from the case and plug it in to my computer directly. Image it, and replace it. All data will be retained.
Aug 17, 2007 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive Logo
719 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
