Question about Sharp Televison & Video
How do I wall mount a sharp aquos LCD TV. - Sharp Televison & Video
SOURCE: Clean screen
I used the Monster "Screenclean" kit, which left a film on my screen. I am not happy with it. Any suggestions on a different product which will remove the film?
Posted on Jun 06, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
dsacco86
  • 1077 Answers
SOURCE: HAVE A SHARP 52" LCD #LC52D65U AND I CAN'T FIGURE OUT HOW TO REMOVE THE STAND SO I CAN MOUNT IT ON MY WALL. PLEASE HELP ME
On the back of your TV, there are 4 long hex bolts. It should have triangles pointing towards the holes. Take the 4 long hex bolts out and the stand itself should slide out with no problems.
Posted on May 21, 2009
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Posted on Sep 27, 2009
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
Need screws for the back of my TV.Wall mount screws for a sharp LC52D92U
If you have purchased a wall mount kit that will fit a 52" TV there will be screws included that will fit.
Mar 15, 2014 | Sharp Aquos LC52D92U Television
NEED BASE STAND FOR A SHARP LC-46SV50U
Go to shopjimmy.com and get a universal stand. It attaches to the back of the TV just like a wall mount.
Mar 30, 2013 | Sharp AQUOS LC-46SV50U 46" 1080p LCD TV -...
Looking for a stand for Sharp Aquos LC-2084U-SM
Nov 08, 2012 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Can't find tv stand for Sharp Aquos LC-32D44U
You can get a universal stand from shopjimmy.com. It attaches to the back of the TV just like a wall mount.
Aug 15, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My tv turns off all by itself
If it can turn on again, it may ok. and you can enter to the service made to see what error is.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Is there a part available to make this TV able to be wall mounted
Try Ebay.com or Amazon.com look up ur tv model and buy parts for the wall mount.
Feb 12, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
May 21, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
How high should you mount a 42" flat screen from the floor?
Depends on where you sit to watch TV.
Usually the view angle must be between 20 and 30''.
Sit on the couch or on the chair and verify at what height you can watch the TV confortably enough.
See also
Introduction to Wall Mounting a Flat Panel LCD or Plasma TV
How to Mount a Flat Panel TV -
Dec 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
47 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
