Question about Garden
GMC 28cc petrol hedge trimmer need to know which way the fine spring fits in the manual starter. It is the spring attached to the release mechanism I am requesting assistance with. Ray
  • 28 Answers
SOURCE: Husquarna petrol hedge trimmer starting problem
it could be extremely flooded with way to much fuel. in the motor.take out the sparkplug turn the ignition switch OFF and pull the starter rope...if there is a lot of fuel blowing out of the cylinder...thats your problem.....buy a new sparkplug and try starting it with no choke and full throttle with the new sparkplug fitted....see how you go.....or its warn out and has no compression to fire up the fuel.....in this case ..its time to upgrade
Posted on Aug 06, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
eugbug
  • 479 Answers
SOURCE: oil/petrol mixture for GPHS 26cc gardenline hedge
Petrol / oil should be in ratio 50 to 1
Posted on May 13, 2011
johnjnail
  • 1702 Answers
SOURCE: I need a user manual
try this web sight, it is one of the largest of the on line manuel sights, i make no promises but they have come threw many times in the past.
http://www.manualsonline.com/?src=12022010
Posted on May 14, 2011
SOURCE: Tanaka THT 1800 Hedge Trimmer
2% (50:1)
see http://tanakapowerequipment.com/pdf/manuals/Hedgetrimmers.pdf
Posted on Jun 03, 2011
Dethatcher
Sorry they do not make a dethatcher for them not enough power .
Jun 27, 2015 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
Husqvarna Trimmer 128LD starter card will not retract
Check the recoil spring in the starter housing, sometimes the rope rotor can jump out the hook on the spring.
Oct 22, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
I have a M line gas hedge trimmer. Where can I get parts and find the manufacture of this trimmer? Thanks Mike
You will need to know the manufacturer and model of this unit in order to get any parts.
Oct 14, 2010 | Husqvarna 28cc Gas Line Trimmer
My edger attachment won't come off
Not too sure of this model,have you tried to spray a "good" loosening fluid,where it is supposed to come off, TAP lightly!!! with a small hammer,LEAVE OVER NIGHT!! try to see if it releases,if not Repeat spray procedure,leave overnight and try again,if you don't have success,let me know,is this a petrol or electric model?? By the way did the machine get wet,when you then stored it away,if so the "good loosening spray" should loosen any rust/gunge that may have occoured,but let me know,rgds benji123
Sep 25, 2010 | Homelite Expand-It Hedge Trimmer...
Jun 27, 2009 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
