Question about Honda 8 HP Engine
HONDA GX 240 8HP ENGINE WILL ONLY START WITH A SHOT OF STARTING FLUID. ONCE STARTED IT RUNS FINE.. WHAT'S WRONG ?
    Sergeant:
  • 384 Answers
Sparkplug needs to be cleaned or replaced.
Posted on Jul 21, 2009
The only way to start it is with starting fluid. After it starts it runs fine. What is my problem?
Typically an engine that won't start without a shot of starting fluid but runs fine has an issue with the choke plate not closing when it should. It may need an adjustment to allow it to close when starting. It would not hurt to change the oil, filters, and spark plug(s) as general PM maintenance.
Apr 25, 2016 | Craftsman Professional 24 hp 42" Yard...
When I run my Honda gx620 pressure cleaner/
Over heating, do you really need to run it for 3 hours in one shot???? Try one hour then let it cool down!!!
Feb 16, 2015 | VTwin Horizontal OHV Engine with Electric...
Starting Problem, engine runs cold acording to guage
c lean your TPS and your MAF sensors and check air filter
Apr 23, 2012 | 1996 GMC Jimmy
Crank no start i shot it w starting fluid it started and runs fine could it be the main injection relay?
This sounds more like the fuel pump itself is bad. You may here it running but it may not be producing pressure. Find the fuel filter and take loose the fitting from the filter to the injector rail. turn on the key you should get steady pressure and longer than 3 seconds. If you have pressure and it pumps out lots of fuel real quick, the pump is good if you get a small amount of fuel and thats it, bad pump.
Sep 22, 2011 | 1994 Honda Accord
Have to spray starter fluid in the intake to get to start. once started runs fine, why?
This sounds like a weak fuelpump, and take a while to build up pressure, the starting fluid get the engine running until the pump builds up pressure, i would have the fuel pressure tested and i think you will find that its bad. good day.
Jun 19, 2011 | 1996 Ford Explorer
87 ford ranger wont start without starting fluid
It sounds like you aren't getting fuel out of the cold start injector... remove the injector when engine is cold and switch on ignition... you should get a fine spray pattern for a few seconds... if not then there is probably a problem with the cold start circuit (Temp sensor fault), or the injector is faulty. pull electrical connectors one at a time and look for corrosion... Hope this helps...;-)
Apr 15, 2009 | 1987 Ford Ranger
1990 Honda Civic DX
Could be coil or ignition module starting to fail
Oct 24, 2008 | 1990 Honda Civic
Honda 8 HP Engine Logo
743 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
