Question about Whirlpool Washing Machines
Whirlpool washer F3 E1 - Whirlpool Washing Machines
  • 59 Answers
F3E1 Error - Pressure switch/ sensor fault.
  • Your washer cannot detect the water level. Check the pressure sensing hose for kinks or blockage or the pressure sensor itself.
  • I won't leave you without a clue. Follow the link below and it will explain more than I can write here.
  • http://applianceassistant.com/Washer-Repair/Duet/Duet-Washer-Error-Codes
  • Posted on Jan 06, 2017
    Front load washer whirlpool code f3 e1
    This is a pressure switch related problem. Take the top off and examine the pressure switch hose. It's usually a thin clear or black hose.
    Oct 16, 2017 | Whirlpool Washing Machines
    Tip
    Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
    Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
    WHIRLPOOL - most models
    Range/Stove and Oven Fault Codes, Common error codes.
    F1 - Analog control board Failure
    Disconnect for one minute - if error comes back, replace control board
    F1 - Shorted control keypad
    Replace keypad
    F3 - Oven temperature sensor open
    Replace oven temperature probe
    F2 - Oven temperature sensor shorted
    F3 - Oven too hot
    F3 - Clean temperature too hot
    Replace oven probe
    F5 - Door latch switch fault
    Test and replace the door switch.
    Whirlpool with 4 Digit Failure Code:
    F1 - E1 - Electronic control (flip flop)
    Replace control board
    F2 - E0 - Shorted control keypad
    Replace keypad
    F3 - E0 - Oven temperature probe open
    Replace temperature probe
    F3 - E1 - Oven temperature probe shorted
    F3 - E2 - Oven temp too high
    F3 - E3 - Clean temp too hot
    Replace temp. probe
    F5 - E0 - Check door latch
    F5 - E1 - Check door latch
    Replace switch if defective
    WHIRLPOOL Polara models 5 digit codes:
    F1 F0 - EEPROM communication error
    Replace ERC
    F1 E1 - EEPROM checksum error
    Replace ERC
    F1 E2:7 - UL A/D errors
    Replace ERC
    F1 E4:2 - Model ID error
    Reinsert keytail.
    F1 E6:0 - Latch signal mismatch error
    Replace ERC
    F2 E0:4 - Shorted key error
    Replace keypad assembly
    F2 E1:3 Keytail unplugged
    reinsert the keytail
    F3 E0:5 Top oven sensor open
    Test and replace top probe.
    F3 E1:6 Top oven shorted
    Test and replace temp probe
    F3 E2:9 Bake range over temperature
    F3 E3:8 Clean range over temperature
    Test and replace temp probe.
    F3 E4:10 Bottom oven sensor open
    F3 E:15 Bottom oven sensor shorted
    F5 E0:14 Door switch errot
    Test and eventually replace door lock switch
    F5 E1:16 Door latch not operating
    Test and eventually replace door latch
    F8 E0:17 Refrigeration error
    Test the cooling module.
    PF Power failure - Does not indicate a fault.
    PF occurs when power is disconnected.
    WHIRLPOOL
    Models SF3, 30'' and 24"
    F2 - Oven temperature above specifications
    Check 8-pin connector from temp. probe to Electronic Oven Control
    F3 - Open oven temperature probe failure
    Check wiring, replace oven probe if necessary
    F4 - Shorted oven temperature sensor failure
    Check wiring harness, replace oven temperature probe if necessary
    F5 - Push button stuck or faulty
    Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
    F6 - Electronic control logic error (timing)
    Replace Electronic Range Control (ERC)
    F7 - Electronic control logic error (lock motor)
    Replace ERC.
    F8 - Electronic control logic error
    Replace ERC.
    on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
    E1 F3 on front load whirlpool duet washer
    We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Washer.
    Mar 02, 2017 | Whirlpool Washing Machines
    Whirlpool gold oven message E1-F3-
    whirlpool oven starts preheating then turns off and sends a message F-3
    Nov 13, 2013 | Whirlpool Ovens
    Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
    Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
    The part comes with a 365 day, any part, any reason return policy.
    Nov 07, 2012 | Whirlpool Ovens
    My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
    This should help any further assistance please feel free to contact me.
    WHIRLPOOL
    Range/Stove/Oven Fault Codes Non Y-Line
    NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
    Failure
    Code
    Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
    2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
    Range/Stove Oven Fault Codes, Common
    Failure
    Code
    Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
    Jul 16, 2011 | Whirlpool Ovens
    Upper oven will not work
    F3-E1 Shorted wire or Temperature Sensor - locate short and correct it or replace Sensor.
    go to RepairClinic.com and enter your exact model # for a listing of replacement parts.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Apr 14, 2010 | Whirlpool RBD275PD Electric Double Oven
    F5E1 error
    Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
    >>Exception Note:<<
    Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
    F0-E0 Analog to Digital failure
    Disconnect panel for 30 seconds
    Should the above error re-appear, replacement of the control is required.
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad Replace Keypad
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
    Whirlpool RF196LX Smooth Top Range
    Oct 21, 2007 | Kitchen Ranges
    Washing Machines Logo
    2,935 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
