Question about Dell Inspiron 1100 Notebook
The solving Problem
How to uninstall K9 Web Protection, because i forget the password
How do i delete k9 from macbook air without k9 password
When you did this did yo get the message that it was uninstalled?
Symptom
You want to uninstall K9 from a Mac computer.
Solution
Note: You must have administrator rights to uninstall K9 Web Protection.
  1. Open the [System Preferences] panel.
  2. Click the K9 Web Protection icon under the "Other" section at the bottom.
  3. Click the [Uninstall] button.
  4. When prompted, enter your K9 administrator password and click [OK].
  5. You will then be prompted to enter your Mac administrator password.
  6. When the uninstall process is complete, you will receive a message saying K9 has been successfully uninstalled.
DO NOT ATTEMPT TO UNINSTALL K9 WITHOUT A PASSWORD. By design, K9 will block all web access should anyone attempt to uninstall without using a password. Attempts to modify K9 at the system level will have the same effect.
Jan 28, 2015 | Computers & Internet
HOW TO DELETE K9 AND IT IS SO ANNOYING ME WHAT CAN I DO PLEASE HELP ME I WANT TO GO ON THINGS BUT I JUST CANT I NEED SO MUCH HELP SO PLEASE HELP IT WILL BE SO GREAT NOT TO HAVE IT
Make sure you are connected to the internet before uninstalling K9 so your license is properly released. If this is not possible, you can continue to uninstall, but you will need to request a new K9 license if you choose to reinstall K9 in the future. Also, please make sure you are logged into your Windows Administrator user profile. Attempting to uninstall K9 from any other user profile than "Administrator" will not work.
  1. Click [Start].
  2. Click [Control Panel] (Note: if you cannot see this option, it may be under[Settings]).
  3. Open [Programs and Features] (Note: This will be called [Add/Remove Programs] in Windows XP).
  4. Locate Blue Coat K9 Web Protection in the list of programs and click once to highlight it.
  5. Click [Change/Remove].
  6. Click [Yes] when you are asked whether you want to completely remove K9. DO NOT ATTEMPT TO UNINSTALL K9 WITHOUT A PASSWORD. By design, K9 will block all internet access should one attempt to uninstall K9 without using a password. Attempts to modify K9 at the registry level will have the same effect.
  7. Enter your K9 Administration password and click [Uninstall]. If you forgot your password, click the "Forgot Password..." link to have a temporary password emailed to the email address on file.
  8. When prompted to reboot your computer, click [Yes].
After rebooting your computer, K9 will be completely uninstalled.
Jul 27, 2014 | Blue Coat Systems K9 Web Protection
How to remove k9 protection
Solution
Please follow the instructions below to uninstall K9 Web Protection. Make sure you are connected to the internet before uninstalling K9 so your license is properly released. If this is not possible, you can continue to uninstall, but you will need to request a new K9 license if you choose to reinstall K9 in the future. Also, please make sure you are logged into your Windows Administrator user profile. Attempting to uninstall K9 from any other user profile than "Administrator" will not work.
  1. Click [Start].
  2. Click [Control Panel] (Note: if you cannot see this option, it may be under [Settings]).
May 26, 2014 | YouTube Computers & Internet
Hi im anthony and i had bought a laptop from a guy and it has k9 web protection on it and im tryn to get it took off can u pleasde help me
there are two methods you can try.
Method 1
If you have the administrator account password for the local computer and the best way to uninstall K9 web filter from the local computer is to re-install it! Re-install k9 web protection will simply get you a new license code and a new password you can enter without the need of old password.
1.Open K9 web protection website 2.Click "get K9 NOW" tab on the top-left 3.Fill out the information and your email. 4.Download the K9 Web protection software from the link included in the email and keep a copy of the license. 5.Grab a version of the K9 web protection installed on your computer, a Google search should do the job. 6.Open "Task Manager" by press (Ctrl+Alt+Delete) and end the process K9filter found in the "Process" tab. 7.Now, you can safely delete the K9 web protection program files. Open computer explorer and go to the folder where K9 is originally installed. It can be found mostly at C:\Program Files/Blue Coat k9 Web Protection. 8.Remove the contents of the folder but not the folder. 9.Run the K9 web protection setup/installer file which has the same version as the one you just delete 10.Provide the license and create your new password 11.Point the installation folder to the same folder you just empty the contents earlier on 12.Now you can have a re-installed K9 web protection with a password you know. How do you uninstall K9 web protection now? Use the new password you just created If something goes wrong, install the K9 web protection program downloaded from Step 4.
Method 2
Reboot Windows into safe mode: restart your computer and hold "F8? key until you see the menu to choose "Safe Mode" Login to windows and go to "Program Files" directory and delete the K9 folder manually (delete only the contents but leave the folder) Click "Start"->"Run" and type "msconfig" Check the tab "Services" and tab "Startup" Un-check anything that is related to k9 If somehow this method is messed up, try to download K9 again to at least restore your previous installation. If this still does not work, try to install Revo Uninstaller.
Here is a video tutorial
Aug 24, 2011 | Dell Inspiron 1501 Notebook
How do I uninstall K9 Protector to enable me to get rid of 'System Tool' malware, because K9 Protector is not responding. System Tool is blocking .exe files.
These are the official uninstall instructions:
Please follow the instructions below to uninstall K9 Web Protection. Make sure you are connected to the internet before uninstalling K9 so your license can be released. If this is not possible, you can continue to uninstall, but you will need to request a new K9 license if you want to reinstall K9 in the future.
  1. Click Start
  2. Click Control Panel. If you can't see this option, it may be under "Settings"
  3. Click Add or Remove Programs
  4. Find Blue Coat K9 Web Protection in the list of programs and click it once.
  5. Click the Change/Remove button.
  6. Click Yes when you are asked whether you want to completely remove K9. DO NOT ATTEMPT TO UNINSTALL WITHOUT A PASSWORD. By design, K9 will block all Internet access should one attempt to uninstall without using a password. Attempts to modify K9 at a registry level will have the same effect.
  7. Enter your K9 administration password and click Uninstall. If you forgot your password, click the "Forgot Password..." link to have a temporary password emailed to you.
  8. When asked whether to reboot your computer, click Yes
After rebooting, K9 will be completely uninstalled.
Mar 05, 2011 | Computers & Internet
How to unistall K9 Web Protection Administration off my computer?
  1. Click the Windows "Start" menu and click the "Control Panel. Double-click "Add or Remove Programs" to launch the programs list if you are using Windows XP. For Windows Vista and 7 users, launch the programs list by clicking "Programs" and clicking "Programs and Features." Scroll down and click "K9 Web Filter." Click "Remove/Uninstall." Click "Continue" on the Uninstall dialog box. Select "Yes" to uninstall K9 Web Protection. Type your K9 password and complete the uninstall. When prompted, restart your computer.
Feb 20, 2011 | Computers & Internet
I want to uninstall my blue coat k9 with out using my password
Click "Start" and open your computer's "Control Panel."
Click "Add or Remove Programs."
3Select "Blue Coat K9 Web Protection" from the list that appears.
Click "Change/Remove." Click "Yes" to confirm.
Enter your K9 password and click "Uninstall."
Click "Yes" to reboot your computer when the process completes.
  • 2 Click "Add or Remove Programs."
  • 3 Select "Blue Coat K9 Web Protection" from the list that appears.
  • 4 Click "Change/Remove." Click "Yes" to confirm.
  • 5 Enter your K9 password and click "Uninstall."
  • 6 Click "Yes" to reboot your computer when the process completes.
  • Read more: How do I Uninstall K9 From the Local Computer? ' eHow.com http://www.ehow.com/how_6885359_do-uninstall-k9-local-computer_.html#ixzz1CpiGZfJL
    Feb 04, 2011 | Blue Coat Firewall
    My uncle installed k9 web protection in my laptop, how can i get rid of it since i dont know the password?
    Solution
    1. Click Start
    You can find many solutions over the net but dont try it else the internet will be blocked.. just ask for a new password and they will mail you... You need to click on forgot password.
    Oct 13, 2010 | Dell Inspiron 1501 Notebook
    Uninstall k9 without a password
    try this instructions:
    This is a totally safe way to remove k9 web protection without a password 1.) Go to http://www1.k9webprotection.com and click on the "get license" tab on the left 2.) fill that out and get the license from your email address 3.) In the email there will be a link to download k9 or just type this into the address bar http://www.k9webprotection.com/download/k9-webprotection.exe You'll need this to reinstall k9 just incase you mess something up 4.) Download an older version of k9 web protection I used K9 Web Protection 3.2.36 which you can download from the following link http://www.shinedownload.com/software/K9-Web-Protection/665.html 5.) Access the task manager (ctrl + alt + del), go to the "process" tab, find "k9filter" and end this process of course after this point you won't be able to get on the internet since you just tampered with the program so make sure you've got the license from your email, the k9 installer, the k9 installer for the older version, and these directions on your desktop or something 6.) Go to the folder k9 is installed in ( C:\Program Files/Blue Coat k9 Web Protection/ is where it should be) and delete all the files in the folder, but not the folder itself 7.) Run the installer for the older version of k9 at this point you'll enter your license and create a password 8.) Install it in the folder you emptied earlier 9.) Now you can log on to k9 and change the filtering to whatever you please or just go ahead and uninstall it Now you should be free of that horrible skank of a program If not, then restart your computer. Or you can reinstall it from the installer you got from the k9 website, get on the internet, and email me at heliumface770@yahoo.com and you and I will solve the problem K9 may have fixed this bug by the time you read this (because that's what they do best) but as of June 24, 2009 k9 doesn't stand a chance of torturing us with their nearly impossible-to-remove garbage any longer.
    Apr 02, 2010 | Dell Inspiron 1501 Notebook
    Dell Inspiron 1100 Notebook Logo
    383 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
