Question about Coffee Makers & Espresso Machines
My Wega Mini Nova Coffee machine wont turn on it keeps blowing my power every time i try to turn it on i did a clean on the machine,
I cleaned the machine but still got nothing
  • 3 Answers
SOURCE: coffee maker doesn't brew anymore
I had the same problem. I read this article and was able to figure it out the probem: http://home.howstuffworks.com/coffee-maker.htm The one way valve and the heater pipe in the bottom of the unit are extremely calcified. I opened the bottom by removing the four little "security" screws. I used a little tiny flathead screwdriver because I didn't have the proper "star security screwdriver and it worked fine. Next, I removed the two orange hoses and soaked them in white vineager. The shorter intake hose contains the one way valve. make a note of which way you remove this hose 'cause it has to go back in in the same direction. Next I propped the unit on its side so that I could put some vineager in the heater pipe and let it soak in there. Next I blew into and sucked air out of the one way hose and then rinsed both hoses thoroughly. Then I used a little piece of a wire coat hanger to scrape out some of the junk in the heater pipe, (especially on the heat side) followed by a little pipe cleaner to get it extra clean. Then I put it all back together. Be carefull that the hoses are sealed ok. I actually cut a little off of them to get a new seal on the side that connects to the heater pipe. There wasn't much room for error though. After getting it all back together I ran a few full pots through it of 1/2 vineager 1/2 water and then a couple of just water. Probably a good time to change the water filter inside the unit too. Also, from now on I'll make sure to use the self cleaning mode more often. Good luck. Kevin
Posted on Nov 20, 2006
SOURCE: ge coffee pot model number 169165 clean mode botton wont shut off
fyi - manual is at
http://www.gehousewares.com/Browse_Product.aspx?content_id=332
Posted on Mar 05, 2009
protek480
  • 1723 Answers
SOURCE: my lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Posted on Jul 22, 2009
SOURCE: The cleaning button keeps flashing after cleaning.
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
Posted on Oct 13, 2009
SOURCE: lavazza coffee machine will not heat up the coffee
For Lavazza A Modo Mio only call 0800 599 9200 -they can help over the phone or if still no solution they will refer you to Lavazza UK who have the answers for AMM.
Posted on Feb 16, 2010
My jura impressa 9 keep saying not enough coffee no matter what i do
bad sensor, you can try blowing area clean with compressed air, pres the helpful button
Jan 30, 2016 | Jura ENA 3 Automatic Coffee Center - Black
Wega nova
Could be a couple of different things.
I'd first check the water level probe to make sure it isn't dirty or damaged.
After that it can be the inlet selenoid valve thats damaged or has limescale in it. If that selenoid is broken it will not allow water into the boiler.
Either way if the pump is running it means the machine is sending a signal calling for water so it has to be something associate with the water level probe, etc.
Dec 16, 2013 | Wega Coffee Makers & Espresso Machines
Delonghi Magnifica taking a long time to heat. Is now 3 years old. regularly cleaned and de-scaled.
Hi sounds like the heating element is burning outand only drawing minimal power. There is a thermostat on the boiler which could be a fault, but it usually blows and the machine wont heat. Dazza REPAIRER
Sep 23, 2011 | DeLonghi Caffe Nabucco BCO70...
Hello, I have purchased Jura Impressa F9 about 4 years ago and have been using it a couple times daily since that time. Some time ago, I have started having problems with brewing coffee on each program....
machine is most likely clogged with old coffee grounds and needs a good cleaning cycle malf 8 is problem with the stoke of the piston can not make a complete cycle thur get your book out for machine and read list for cleaning machine follow remove power cord for a few mins. let machine cool down if hot from prior use then plug back in power up and do cleanning cycle with tablet follow book worst case would be oring seals on piston are no good or very dry making machine work to hard to move piston in this case service is needed good luck steve
Sep 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Keurig Mini Wont Brew Water won't come out
Had that happen just this morning with my mini-keurig, the needle was horribly clogged. Found a solution on another forum that said to stick a straw over the needle that punctures the cup and blow really hard, then suck really hard and it pulled the debris right out! Then do a cleaning cycle (water&vinegar) to clean out any buildup.
Jul 06, 2010 | Keurig B30 Mini Coffee Maker
Wega coffee machine
Are you on Well water or distilled water?
If no then check the inlet solenoid valve, on the model of your machine it would be an electrical box with 2 pipe fittings on it, usually on the side of the machine.
Does the problem occur when the machine is turned off?
If yes then there is a leak either on the manual fill, or the exchanger in the boiler(happens when a machine freezes), or the inlet solenoid is leaking.
Does the pump run when the boiler is filling?
If the pump runs then the probe is calling for water and it needs to be replaced or cleaned with a wire brush, also check the electrical connector on the probe that could be damaged. If the problem is still happening then the auto level box is damaged.
Jun 28, 2008 | Wega Mininova EPU Espresso Machine
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
