Question about Saeco Coffee Makers & Espresso Machines
SAECO Magic De luxe SUP 012 There is water leaking from a small square with white rings to the left ABOVE/BEHIND where the drip tray doesn't reach. What is this? And how do I fix it? Please help me!
3 Suggested Answers
espressodoc
  • 29 Answers
SOURCE: saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Posted on Aug 27, 2007
dutchman05
  • 487 Answers
SOURCE: Saeco Magic de luxe SUP 012
open the machine up and follow the line from the spout (which should give the coffee) till the boiler. The spout most likely is clogged.
Follow THIS LINK for parts etc,
Posted on Jun 03, 2008
There's is water leaking inside my Saeco Magic Deluxe superautomatic espresso machine. Is it a bad boiler?
i had a similar problem and found it was just a gasket on the boiler that wasnt sealing properly.i used JB WELD to repair mine.check all connections and/or gaskets for signs of leaks or possibly a broken gasket mating surface.
Dec 30, 2011 | Saeco Magic De Luxe Espresso Machine
We have a saeco magic deluxe maker SUP 012 that has a cracked water reservoir. We would like to order a new one. Could you please advise us? Thanks
Howdy, they don't have a central online parts distributor, but rather several physical locations throughout the states. I was able to get their customer service number, though, which may be of the best use to you.
Saeco Customer Service at 1.800.933.7876
hope this helps:)
Farmerbear
Aug 31, 2010 | Saeco Magic De Luxe Espresso Machine
Coffee doesnt flow but water gathers in the drip pan instead.
Hi Your problem is probably the boiler leaking. Its located just above the drip tray in the center of the machine. When it starts leaking it goes into the drip tray or on the counter top. If you can remove the top, you can see if the boiler is leaking. There will be a white line between the 2 halves of the boiler.
Feb 09, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe is leaking water
Either two faults, one is that the boiler is leaking ( fix this straight away as water can spray on main circuit board and short out ) very costly to repair if both needs replacing. Second the water runoff to the front tray is blocked with coffee grime . Instead of the water left over when the brewer dissengages running off to the front tray it overflows into the machine. Hope this helps
Aug 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic type sup 012 problem
Hi sad_loser
Your problem is easier. On the top left side of the brew unit is a thumbscrew that holds the filter screen in the brew head. See if you push down on the thumbscrew you can get the filter screen to move? If it dose pull down on the filter screen and see if it will come out. If it does there will be an extra nut on the screw end and that needs to be removed and you need to order a new thumbscrew. That is why we call it a thumbscrew. It only has to be finger tight. The key is only for removing.
Dec 05, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Machine coffee grinds drawer overfills with water
Hi The thumb screw on the brew unit is stripped. If you remove the brew unit and you have water where the thumb screw is its stripped. you just need to remove the old one and replace it.
Oct 13, 2008 | Saeco Magic De Luxe Espresso Machine
Jun 01, 2008 | Saeco Magic De Luxe Espresso Machine
Temp light not on and coffee is dead cold.
I think your boiler is broken, look at www.saeco.com to locate a service center near you
Oct 28, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe cleaning grinder
Aug 20, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
49 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
