Question about LG Dishwashers
Where is the pcb situated on lg 2040wh dishwasher
  • 731 Answers
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Posted on Sep 27, 2009
  • 106 Answers
SOURCE: E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Posted on Mar 30, 2010
SOURCE: Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Posted on Jan 13, 2011
LD-2040WH
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 27, 2014 | LG Dishwashers
LG LD-2040WH Dishwasher problems: It appears the bottom spray arm of my dishwasher no longer rotates or sprays. I had to replace it several months ago and the new one has been fine until now. I removed it...
this dishwasher had many design flaws that generally cannot be fixed even with multiple service calls. lg has scrapped the design and replaced it with their "direct drive" line of dishwashers specifically to remedy the problems with stationary spray arms. my advice would be to replace the unit.
Sep 26, 2013 | Dishwashers
My LG dishwasher LD-2040WH washed and as soon as the element goes on it switches off by itself. I put it on the gentle cycle and then it switch off and now there is nothing going on it is completely dead...
see the w. diagram for test
1) Test the switch door for defective, this switch can be open or defective and can be open the starting relais and turning off the main motor.
2) Timer: test for defective, clean contact, repair wires loose, broken, or burn.
May 09, 2012 | Whirlpool 24 in. DU940QWD Built-in...
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Nov 28, 2009 | LG Dishwashers
E1 leakage error
Aug 30, 2009 | LG Dishwashers
LG DISHWASHER WORKS BUT VERY NOISY MODLE:LD-2040WH
The main water pump on this model does not last long. The water seal between pump and motor starts to leak that result in the adjacent motor bearing corroding and eventually failing, resulting in excessive noise. Later the water leak becomes so bad that it triggers the "E I" water leakage display and prevents it from completing the program. The pump and motor is sold as one unit and the whole unit must be replaced. I have tried to replace the faulty bearing and repacked the rubber seal with silicon grease but with no success. If anyone have repaired the water seal successfully please let us know.
Jun 15, 2008 | LG 24 in. LD-12BW5 Free-standing...
E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Oct 14, 2007 | Whirlpool 24 in. DU940QWD Built-in...
Dishwashers Logo
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
