Question about Tally T2250 Matrix Printer
Tr01302.500 file problem in tally
This problem occurred after sudden power failure, no ups is attached to my system, date is not changing
  • 44 Answers
Your CMOS battery is a problem.. replace it a new one
Posted on Jul 21, 2009
How to export tally 9 to excel sheet
Great question and there are two way export date. Please follow step by step instruction.
  1. In the Balance sheet screen click E : Export or press Alt+E.
  2. Select the required language from the list of Languages displayed.
  3. Select a format from the list of Formats displayed.
  4. By default, the exported file will be stored in C:\Program Files\Tally.ERP 9 for Windows 7 and C:\Tally.ERP 9 for Windows XP operating systems
  5. Press Enter to accept the default Output Filename or type the filename of your choice in order to save the file with a different name.
  6. Press Enter to accept the default Output Sheet Name.
  7. To update the existing file select Yes in Update Existing File.
  8. To format the contents of the file select Yes in Excel (Spreadsheet) formatting.
  9. Select Yes for the Field with Colour, to retain the background colour in the exported file.
And Second:
selecting the ASCII (Comma Delimited) format, the user can export all the reports or data from Tally.ERP 9. The data exported is converted to plain text separated with commas and stored in a file with the extension .txt. This file format is widely used for emailing and used for importing data into another company using Tally.ERP 9
More information please visit this link.
http://www.tallysolutions.com/website/CHM/TallyERP9/Data_Management/Export_Formats.htm
Thanks,
Jun 10, 2014 | HP Office Equipment & Supplies
When i migrate tally7.2 data to tally erp9 error occur migration is unable to reach tally erp9 server
This Error with migration of data occurs when the connectivity is not proper with the Tally ERP ODBC. It includes the IP:Port.
The Default port for Tally ERP is 9090.
To change the port go to the installed tally ERP 9 folder. Click on Tally file type Configuration Settings, open it with a text Editor i.e. Notepad. Somewhere at the bottom will be ServerPort. Change the ServerPort to 9090. The migration will work. I have tested. Works fine with me.
Apr 26, 2012 | Computers & Internet
How to change date in tally accounting
tally date its not set the date is 1& 2 it is change & next dates not changes or continue what's the problem..
May 19, 2010 | Computers & Internet
How to change date in tally as per attachment?
To change the Effective date, press F2 in the Receipt Voucher entry screen. This will bring a small window that prompts you to enter the DATE and EFFECTIVE date.
If you wish to disable the EFFECTIVE DATE field, then use option "Gateway of Tally -> Accounts Info -> Voucher Types -> Receipt -> Alter" and then set the fields "Use Effective date in Voucher entries to " NO.
Sep 11, 2009 | Microsoft Windows XP Professional for PC
Tally 5.4 file is damaged
Try re-installing operating system/program.Other wise tou need to let me know what o/s and what error message.
Thank you
Sep 10, 2009 | Computers & Internet
Tally v7.2 educational error
  1. You can make a system restore point while installing Tally. But before restoring the same point you should remember that you data can be lost in this process so take an external backup of your data on CD etc.
  2. You can go in back dates by changing system date and see if Tally is working or not (Some times it works !!).
  3. You can insure that your system name, lan cards etc. Doesn't change.
  4. If you know that a trouble is coming ahead e.g. you may need to upgrade system or format the system then best solutions is that you first surrender the tally before formatting.
  5. If you are in deep trouble an and cannot connect internet the surrender the tally in offline mode and keep that file in a pen drive or CD along with your data backup.
  6. If you are in much deeper trouble and finds out in the morning that you computer doesn't start windows and last option is to format it again, then try to start windows in DOS mode and recover that data files by copying whole Tally folder in to another drive. Then you can write mail to support@tallysolutions.com stating your Sr..No and contact person name to reset your licensing info. Wait for the response and then activate the Tally.
Thanks for using fixya.....
Sep 06, 2009 | Computers & Internet
Tally 5.4 error
try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
[Tally]
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Jun 22, 2009 | Computers & Internet
Tally corrupted file
My tally 7.2 files are corrupted due to power failure
Tell me how can I repair these files
Jun 21, 2008 | Tally T2250 Matrix Printer
File is damaged
you please format the system after back up data.
Jan 03, 2008 | Computers & Internet
Tally T2250 Matrix Printer Logo
129 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
