Question about Dyson Vacuums
The power brush on my dyson dc17 upright vacuum makes a horrible grinding noise then stops working. do I need to replace the motor for the power brush? if so how do I find diy instructions?
I have already cleaned the entire power brush area and checked the belt so i am pretty sure that niether of these is the problem. also, I am not concerned about voiding a warranty as it is no longer under warranty, I need to fix it myself as I can't afford to take it to a repair shop.
  • Dyson Master
  • 1,379 Answers
It could be the brush roll and / or belt. Remove those and see how the motor sounds without them in the machine.
Posted on Jan 03, 2017
  • 2 more comments
  • Rhonda Mcmahan
    Rhonda Mcmahan Jan 04, 2017
    thank you that was an important step in the process of elimination I had skipped. unfortunately, it still does the same thing with these items removed.
  • Thatvacguy.com Jan 04, 2017
    It is most likely the motor then. I can get a new motor for you if needed. Gary 260 244-3447
  • Rhonda Mcmahan
    I ordered one from amazon I should have it in a couple days. now I just need to find detailed instructions on how to replace it. thank you very much
  • Rhonda Mcmahan
    Rhonda Mcmahan Jan 07, 2017
    can you please tell me where to find an instructional video on how to replace the brush motor on my dyson dc 17 upright?
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My husband ran over my daughters shirt with our Dyson DC17 animal. Now it's making this horrible load ratting noise. I've taken the head off. Clean the beater bar. The belt is in tact. No
First make sure there are not any of the rubber cogs missing from the belt, it may be wise to replace the belt anyway because the cogs may be worn. Make sure the brush roll does not have any play in it anywhere and that It fits tightly in the nozzle housing without any play. If there is any play or wiggle that will cause it to move.
Apr 21, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc17 animal stopped sucking. brush still
Make sure the flexible hose that connects the beater brush housing up to the connection up by the dust bin is still connected. It could also have a hole in it so check for that as well.
May 23, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc 17 vacuum. brush not moving
The cog belt is probably not aligned with the motor gear. Watch this video and follow its instructions closely.
Apr 05, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Two things that looked like nails came out of my Dyson and not it is making a horrible noise like there is something bubbling inside. How do I fix it?
Sounds like you had some mounting screws come loose from the roller brush motor. There is no way to get at that part of this machine. It will need to go back to the factory and get it refurbished.
Dec 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson D17 is making an incredibly loud noise, like grinding, when the bottom brush rotates.
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Aug 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
When I put the vacuum in position to use on rugs, it makes a horrible grinding noise like something is stuck.
Hi If the Dyson model you have has a protected brush model (i.e. roller wheel at the side that goes up automatically to turn off the brush roll) then the belt will have to be replaced by a Dyson engineer. If its not that model and doesn't have the brush roll stop function, check that the roller beater bar and the brush are properly aligned, also checking the main dust channel isn't clogged.
Feb 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loud noise
I think you damaged the belt. I ran over a sock once and it made a grinding noise but still worked for several months after the incident. Finally, the belt broke off. I had it replaced and now it doesn't make that sound.
Sep 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
178 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
