Washing Machines Logo
H
HENNIE Posted on Jan 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IT IS NOT PUMING WATER OUT AFTER CYCLES - Washing Machines
Jorgie the appliance guy
Level 3:
Top Expert:
  • Washing Mach... Master 5,639 Answers
  • Posted on Jan 13, 2017
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1521735
Points
32630
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
1helpful
My Simpson eziload 750 will not shut off the water during cycles when supposed to
Start machine as normal. After a few seconds of filling, press the pause button. Water coming in should stop immediately. If it hesitates then stops or does not stop at all you have a faulty inlet valve. Change it.
A downeast hot tub water is only 78 degrees turn up to 100 doesn't never get warmer and shows a ECn code
Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
2helpful
On my hot tub control panel Balboa M1 is the code Ec?
Your spa is in Economy Mode:
Ecn or Ec MessageEcn or Ec Message
Hot tub in EC with light flashing
Ecn or Ec Message
Ecn or Ec Message
2004 nissan sentra have problem pumping gas
When you're pumping gas, does it stop you at the end, when the tank is nearly full, or is it not letting you pump gas at all? And how does the fuel gauge read after you've added gas? If it stops you and it still says the tank isn't full, it could just be that the float in your tank that connects to the gauge is wrong.
3helpful
2answers
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
2answers
The tub will not move back and fourth very well.clothes ome out soaking wet.
Something must be either in the pump or filter.9a2d46e.jpg 8132c08.jpg7788fff.jpgOR it could be something in between tubs. If that was the case you would remove the heater and fish out the item.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Beko DE 2431 FW dishwasher
hi there.....when the machine brings water in...have you cancelled the program reselect a program and checked that it is puming out..if all is ok then you need to check that the main wash pump rotates freely....if all is ok here..then i suspect you have a failed capicator on the wash motor....little white cylinderical component on top of the motor
regards Sir Galahad
3answers
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Top Washing Machines Experts
john h
