Where do I attach my turntable to the back of this amplifier mx751p
    Top Expert:
  • Audio Player... Master
  • 41,831 Answers
Attach to the PHONO input if there is one.
How to record from vinal to cd
Amplifiers that you can plug turntables into have a special input for turntables. You can't just plug them into the same input that you would plug a CD player into or some other "AUX" source. Turntables have a different impedance. You will have to have to have one of those amplifiers and then use the "line out" connectors on the back of the amplifier to connect to your computer using the MIC jack on your computer. If you can record your voice on a CD using a microphone, then this should work.
Feb 02, 2015 | Bush RPA 1 Turntable
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
Power supply Sony PS-LX10
Connect the RCA phono plug wires usually red and white wires with plugs to a receiver or amplifier in the back of it to phono in. New receivers will not work unless you have a phono preamp. Best to buy a vintage stereo receiver or amplifier with the correct connections. Make sure you connect the ground wire which is usually a small black wire coming from the turntable to an receiver or amplifier. Turn the stereo receiver on phono. Connect it to any screw attached to metal on back or look for a ground screw. If you do not attach it it will hum.
http://www.hardwaresecrets.com/imageview.php?image=357
Apr 18, 2014 | Audio Players & Recorders
My teac p-595 turntable has a grounding wire that is looped at one end but I don't know where the loop goes. The wire on the other end is fastened to the receiver.
The ground wire should be attached to the metal chassis or the tone arm metal assembly, the other end should be attached to the metal chassis of the amplifier. If the ground wire is not used, you will get real loud hum through the amplifier.
Nov 23, 2010 | Teac P-A688 Turntable
How can i connect a gemini turn table with a ground cable to a input that dont have the ground connection gchristinam@yahoo.com
See if you can attach the ground wire to a point on the chassis of the device you are connecting it to.
Sep 06, 2010 | Gemini XL-500 Turntable
Problems connecting turntable to amplifier
I hope you have it connected to the Phono input on the left rear of the receiver. Otherwise the minute signal generated by the phono cartridge is too small for the other inputs to process.
The buzzing noise/bad channel is probably a bad connection in the tonearm/headshell connection or one of the 4 wires attaching the cartridge to the shell. If you DON'T want to blow up your speakers, TURN YOUR RECEIVER OFF, turn the volume to 0 or select another input before messing around with the tonearm.
Swap the two channels from the tonearm to the Phono connectors to prove the buzzing is external (at the turntable). I think the Dual CS415 uses the old standard headshell. With the volume down flip the lever toward the back, carefully remove the assembly and look over the tiny multi-colored wires with the brass crimp-on ends. We're looking for tight kinks or broken wires. Then put it back. maybe reseat it a few times to wear off any oxidation and try it again.
Apr 01, 2009 | Audio Players & Recorders
Where do I attach the ground wire to the turntable?
You need to attach the ground to a special ground "lug" or "screw" on the next item in the chain.
If this is a dj style mixer then there SHOULD be ground pins on it that you can connect to.
The same applies to a hifi amplifier with phono stage, they generally have ground terminals.
If not you can fasten if securely to the metal casing of the amplifier as this is the same thing.
Technically you can connect it to mains earth but it is ill advised to tamper with mains electricity unless properly qualified.
Mar 28, 2009 | Technics Audio Players & Recorders
Can a turntable be hooked up to this receiver?
The Aux function is not meant for that purpose.The turntables/Record Players being way too old,now a days the amplifiers do not come with PHONO function that was specially used for playing Records/For turntables. Check if u have a phono function in your amplifier and if not then buy another amplifier with Phono function coz you need a ground wire [that comes out from the turn table] also to be attached to the amplifier and then only you can get a proper sound.
Feb 28, 2009 | Yamaha HTR-5440 Receiver
Volume is low on my turntable
You have to amplify the output from your turntable output to the input of your amplifier. To do this you can buy what is known as a pre-amp. Radio shack probably still sells them.
Be sure to ground your turntable to your amplifier and not the pre-amp. This should stop any hum or at least diminish it. Bear in mind that your records will not sound as loud as your CD's. Hope this helps.
Feb 10, 2009 | Numark TT1520 Turntable
Turntable connection
you can not connect a turn table in any other input source other than Phono input my friend. turntable has got very weak signal thathas to be pre-amplified before getting a signal just right for a CD/Tape DVD input. you require a phono am to get an audio signal.
Mar 29, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
