Question about LG Refrigerators
My LG Model LFX31945ST /02 refrigerator is not cooling. It has power. How can I troubleshoot/fix this issue?
Repairman reset button on circuit board and then fan and compressor ran, but stopped after he left.
  • 1122 Answers
SOURCE: refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Posted on Nov 04, 2008
SOURCE: GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Posted on Dec 13, 2008
  • 63 Answers
SOURCE: Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Posted on Mar 20, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Posted on Nov 13, 2009
Macmarkus
  • 2605 Answers
SOURCE: Maytag refrigerator isn't cooling
Hi ****, Based on the discription you've provided it sounds like either a faulty start relay or the compressor is seized. If you have a multi- meter you can check the compressor to see if the windings are ok. Unplug the fridge. Remove the panel at the back down at the bottom. This should gain you access to the compressor. On the side of the comp. will be the start relay/overload assembly. Pull off the relay & overload and you'll see 3 pins in the form of a triangle. With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin. You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms. On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good ! If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit. This will start it if it's not seized also known as a "locked rotor".. You can find them at most brick & mortar appliance parts locations or on-line vendors. The package contains info on how to connect it. If that doesn't yield any results moving forward, let me know we'll go from there. **I suggest you phone Whirlpool customer support first though ( they own Maytag ) as they recently had a massive recall regarding the starting device of many compressor's and you may find your's to be included therefore have it repaired at no cost.** they will know by your model and serial number or if that isn't clear the number on the compressor. Good Luck Thanks for visiting "fixya", please take a second to rate my solution and leave a comment/testimony to it's helpfulness. macmarkus :)
Posted on May 02, 2010
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
Dec 21, 2014 | Maytag MSD2756G Side by Side Refrigerator
LG fridge is not working. NOT COLD in FREEZER or REFRIDGERATOR LED in main circuit board keep flashing
Look for a reset button, and try resetting . If compressor , is working and still not cooling , check refrigerant gas.
Oct 17, 2013 | Refrigerators
LG Refrigerator not cooling
Call a technician because either a board was burnt out or the compressor or the start device for the compressor took an excessive load and is shot.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 06, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Model 685 Manufactured 02/04. EC 08 20 40 50. For a few months power off/on resolved the issue for a week but recently fridge side not keeping its cool. Freezer seems good. No condensation in fridge. ...
More than likely the control board in the refrigerator section has failed. The only thing that would cause this issue it a control. The breaker reset was only resetting the software in the control board.
Replace the board on the side and it will fix this issue.
Apr 13, 2011 | Sub-Zero 690 Side by Side Refrigerator
Mitsubishi VS-55707 Rear Projection - Power button turned on, green light on television shows power but automatically shuts back off within a couple of seconds.
My brother had the same issue. I have the same set as well with this very issue. My brother had his fixed: repairman soldered the circuit board???? My brother could not tell me where on the circuit board or what circuit board???? IF there is anyone that knows about this....it would be helpful. I DO NOT WANT TO have someone else do what I can fix myself....besides by the time I pay a repairman I am 1/3 of the way or better to a new set anyway!!! Thanks a bunch - Pam
Apr 18, 2008 | Televison & Video
Samsung model RS2577SL
That just worked for me too. Hold the power freeze and power cool buttons down at the same time and it will reset it after a power surge. All I had working was a light inside the door and a blinking green light on the display panel.
Jan 11, 2008 | Samsung RS2578BB Side by Side Refrigerator
Samsung side-by-side refrig is not staying cold
Look for signs of frost build up on back freezer panel. If there is build up then it has a defrost problem. I haven't had much experience with samsung but I beleive it has a fuse in the defrost circuit on the evaporator and that may be the defrost problem.
Sep 28, 2007 | Refrigerators
Refrigerators Logo
168 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
