Question about Tablets & eReaders
Want to upgrade this tablet with a program to make it run fastr and be a lot smarter
Why is my nextbook tablet getting so hot
If you run programs that require lots of power the battery will get hot, video is one such hi draw program and video gaming.
Sep 17, 2017 | Nextbook Tablets & eReaders
What is wrong when tablet says thermal critical event occurred and tablet shuts down?
This means the tablet got to hot and presented a fire hazard. Only a few things cause the overheat, first is a failing battery and the last running data heavy programs like complex video games. Those types of programs draw a lot of amps and can overheat the tablet.
Mar 21, 2017 | Tablets & eReaders
My tablet won't install system updates.
Its the upgrade program make sure it's original upgrade software that's compatible with unit
Sep 02, 2016 | Tablets & eReaders
Not downloading to the sd card
If you are referring to apps you are downloading, that is probably correct. Most apps will not use the SD card to run (or load). It takes more programming for apps to use the SD card than not to, and since many users do not have an SD card installed, most apps won't use it. That is the falsehood that comes with tablets and eReaders. Users are led to believe that even though the tablet may not have a lot of internal memory that they can add an SD card. That works fine for personal files and photos, but not for apps and their data. Users need to know that if they want a lot of apps on their tablet, they need a tablet with a boatload of internal memory.
Dec 06, 2015 | Tablets & eReaders
I need help how to put my tablet on recovery mode its a smartpad ep750 it has no volume butons
I have had this problem a lot lately plug it into another computer using the usb port and repair program like system mechanic also run anti virus check using the other computer it should unlock it and get you back up and running.
Aug 03, 2015 | Tablets & eReaders
Why is my coby mid 8042 running slow
You either have too many Apps running (at the same time) or you have been hacked with a virus. I would venture on the first one. You have to see what programs (Apps) you have running and attempt to shut them down. Then your machine will be happy. Or upgrade the RAM if possible.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 19, 2014 | Coby Electronics Corporation Coby Kyros...
How do I do a firmware update on android notebook?
I don't see have the steps you were given, (let battery get very low then get an SD card) is going to do anything to fix this. Without knowing the make and model there's not a lot to go on. What version is it running? Jelly Bean? Kit Kat?
Have you done a reset? Holding the power button in for 10 seconds until it shuts down completely? I'm not sure that doing a firmware upgrade is going to fix this. If you can get the tablet to run long enough you could try it, but if it freezes up in the middle of it, you could break your tablet.
Oct 07, 2014 | Tablets & eReaders
I have a Wacom Bamboo tablet, which runs perfectly after I start my computer up, but operates extremely sluggishly after I resume from hibernation. I have the most recent drivers, and the sluggishness...
The trouble might be Windows 7, sine it is not supported any longer and the drivers might be for Windows 10.
You might have to upgrade to Windows 10 to fix it or take it to a computer shop.
Feb 06, 2018 | Wacom Tablets & eReaders
Download firmware for m750b tablet
Be aware you need a working tablet to update. the program must be in working order and the processor must run. Once you start the upgrade, there is only a small routine running, to put the new program in the right place in the Flash memory. You don't get a second chance, if anything goes wrong, because even the routine to update can't be put in place or run.
An update is NEVER a solution for a bricked tablet.
Please check some forums what to do with your problem, but please don't brick the device with an update you can't get in place.
Dec 28, 2012 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
