Question about Sharp AR-M550U Copier
I have sharp ar-m550u printer and there is ar-p19 printer kit the problem is i cant enable it becase he ask for product code but i lost it but i have product code for ar-p19 >> any soluotion plz
    New Friend:
I lost the file optin on AR-M550U how do i get it back?
Posted on May 04, 2017
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Posted on Jan 11, 2009
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
007tech
  • 95 Answers
SOURCE: With a Sharp AR-M550U copier getting a CE-03 error
It means the copier is having ttrouble accessing the network resources to send the email. If you are still able to print to the copier without any problem then the issue will be with your email setting on the copier. Check to make sure you have the correct SMTP server info and the DNS and Domain info. Your email connection may also need authentication. If any of this info is incorrect it will give you this error. Was it working before ? Has your service provider or you changed your email information?
Posted on Jan 15, 2010
007tech
  • 95 Answers
SOURCE: Sharp AR-M550U get error code:F2-31
F2-31 is related to the image process control for the drum. The drum sirface is read by the image density sensor - if it has a problem doing so then it will give this code. Possible causes could be a bad/old/worn drum or the drum is not being cleaned properly by the drum blade. To run the processor control adjustment do the following : press the "P" key then "*" key then "C" key then "*" key again. this will bring you into service mode. (warning : please do not make any other adjustments in this mode as you can do some serious damage to your copier). then type 44 and press start key then 2 and start key again. Once it is finished running restart the copier. If this fails you need to look at the drum and possibly change it.
Posted on Feb 08, 2010
Testimonial: "very helpfull.Thanks"
rezazadeh
  • 328 Answers
SOURCE: Sharp AR-M550U code H5-01
enter code 14
Posted on May 29, 2010
I lost my key operator password for my sharp ar-m550u, how do i recover?
Touch # * C * on the panel
touch 22, then the start button
touch 7, then the start button.
it will display the code on the screen for you
Copier Collin Houston TX Copier and Imaging Expert
Jul 13, 2014 | Sharp AR-M550U Copier
CALL FOR SERVICE.CODE:U7-00
According to the error code manual, it means "U7 00 PC/Modem communication trouble" - You can download the entire list of all codes at the link below. It includes your machine specifically. Hope this helps. http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm550n_m550u_m620n_m620u_m700n_m700u.pdf
May 27, 2014 | Sharp AR-M550U Copier
How can i get aproduct key online ?
Your request is confusing and lacking details, but I'll try....
The base model 550U has USB and parallel printing capability. Networking comes standard on the 550N but is an add-on option for the 550U in the form of a "print expansion kit" made up of a NIC, 2 flash rom that plug into the main control board, and a product key. If the area where your print ports are located has a network CAT-5 plug, it means your expansion kit is installed, your product key has somehow gotten zapped and you need to re-enter it. The model number for the kit is AR-P19. If you have the P19 box with the registration sheet, the product key may be written on it. Product keys can be obtained online but only a Sharp dealer has access, sorry.
May 01, 2014 | Sharp AR-M550U Copier
I want to download drivers for Sharp AR-M550U
you can Find any Sharp Driver From here :
http://www.sharpmea.com/cps/rde/xchg/ae/hs.xsl/-/html/support--downloads.htm
this is the Official Driver's search engine for all sharp products Download Center
Apr 04, 2014 | Sharp AR-M550U Copier
CALL FOR SERVICE.CODE:F2-00
Greetings to meet code F2-00 on Sharp copier What should I do. Need help.
May 23, 2011 | Sharp AR-M550U Copier
Code F2-00 on AR-M550U
Change the toner catridge
Jan 15, 2011 | Sharp AR-M550U Copier
ER-M550U GET ERROR CODE E7-60
controller connection trouble if you are technical then power down the unit and unplug it ....remove rear cover and reseat all connectors....if you are not technical then call for local service rep....are you in the midwestern usa?
Mar 05, 2010 | Sharp AR-M550U Copier
Feb 06, 2010 | Sharp AR-M550U Copier
SHARP STAPLES
For the AR-M335U/455U-they are AR-SC2,5000 staples                            AR-M550U/700U,N-they are AR_SC11 staples                     They are a box of three. Hope this helps
Oct 17, 2007 | Office Equipment & Supplies
Sharp AR-M550U Copier Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
