Question about Dometic Heating & Cooling
Why does the dometic take so long to wash - Dometic Heating & Cooling
  • Dometic Master
  • 3,228 Answers
Hello KAREN DOWLING,
The number 1 reason new generation washers take
EXTENDED times to wash... is the operators
FAILURE to read & heed the need to use te new
HIGH EFFICIENCY DETERGENTS... ("HE").
It may take a while to restore your machines efficiency if this has been going on for a while... USE of common detergents overpowers the sensors that are critical to the
PERFORMANCE of the "HE" washers and it takes
good hot water and proper cleaning agents to restore that efficiency.
There are remedial cleansers that can be purchased and used ...
or the machine my simply NOW NEED REPAIR.
It is ALWAYS best to follow MANUFACTURES
instructions...
The "HE" instruction was not a SUGGESTION...
It was a MANDATE.
Carnac the Magnificent
Posted on Jan 03, 2017
We have a dometic wmd1050 front loader washing machine in caravan we did some washing today went through washing cycle ok lights went out on door lock but can't open door how do we open door
The latch assembly broke so you will need to use a screwdriver to manually release the latch. It will not be easy to get the door open, you will need to get in behind the latch and pry slightly to the left. The parts breakdowns are available below so you can see what you are up against. See the 4th page at the URL below.
http://caravansplus.com.au/pdf/WMD1050-Spare%20Parts.pdf
Apr 17, 2017 | Washing Machines
Why does the dometic washing machine take so long to wash just to wash over an hour
Is it a front loader? They take much longer as a way of saving a lot of water.
Jan 02, 2017 | Star Washing Machines
Can you replace Dometic 3107541.009 analog control unit with Dometic 3313192.000 digital control unit?
e-mail or call dometic support : (www.dometicusa.com) and make sure you give them the model # of your control box at ceiling assy and they will tell you if they will work together.
Jul 30, 2014 | Dometic 3107541.009 Analog Thermostat...
How to remove filters in dometic airconditioner in 2012 winnebago
There should be 2 squeeze clips at one side of the intake cover. Squeeze these inwards and the intake cover will swivel down. The filter(s) should then slide out. Wash them. Do not vacuum or brush as that will wreck the filter material. Just under a running tap is fine.
Aug 31, 2013 | Dometic Rooftop RV Air Conditioner
PART # 7330B730 SERIAL # 109734610 1997-TIMBERCREEK R.V.
most of the time the condenser coil is dirty and needs to be washed out. with it dirty the pressures are elevated and causes compressor to kick out on overload. try washing cond. coil first
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
How do I clean out the vents in my RV Dometic roof ac?
Take it off,the plastic inside vents, with soap water and a hose wash it.  Outside condendor and inside evapator, making sure the drain is open and outside shroad removed, brush off fthe loose stuff. wet both units, put liquid dishwashing soap on both. Spray then through , with a hose untill they rince clean.  While up there. Oil the motor if possible.  Keep the drain clear and open,making sure none of the water is getting into the RV.
May 08, 2009 | Dometic Rooftop RV Air Conditioner
Have a Dometic WMD 1050 front load washing machine and can not open the door
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 26, 2009 | Washing Machines
Heating & Cooling Logo
35 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
