Question about Amazon Fire TV Stick
Fire stick remote stopped working. - Amazon Fire TV Stick
Tip
Amazon fire stick reset
make sure that your wifi is a good signal,if you are using a lower tier internet service then it wont work,call your internet provider and verify that your internet is sufficient,also use 5ghz wifi,not 2.8ghz.
if this doesnt work for connecting then,
reset this way,
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
also,xfinity remote controls work with firestik tv in place of the original remote,program it for a vizio tv and forget the original remote!
on Apr 03, 2015 | Amazon Fire TV Stick
Lost my fire stick remote. can my phone be used as a remote?
apparently it can!
Amazon Fire TV (Stick): How to Use Your Phone as Remote Control ...
streaming-blog.com/amazon-fire-tv-stick-how-to-use-your-phone-as-remote/
  1. Cached
  2. Similar
Sep 13, 2015 - Make sure that the Phone with App and the Fire TV are connected to the same Wi-Fi network. ... Enter this code on your Phone. Done. You can see all of the remote apps that are paired with your Amazon Fire TV device under "Settings > Controllers and Bluetooth Devices > Fire TV Remotes".
Amazon.com Help: Download and Pair the Fire TV Remote App
https://www.amazon.com/gp/help/customer/display.html?nodeId=201640980
  1. Cached
  2. Similar
Fire tablets (with a microphone); Amazon Fire phone; Android 4.0 or higher ... Note: The Fire TV Remote App is compatible with Amazon Fire TV devices with ... settings on your router, you need to enable Multicast support to use the app. If you're not sure how to manage these settings, your router manufacturer will be in the ... Lost my fire stick remote can my phone be used as remote Google Search
Dec 31, 2016 | Televison & Video
How do i know alexa remote for fire stick will work in my area
need to notify manufacturer for compatibility or regional area of operation
Oct 15, 2016 | Amazon Fire TV Stick with Alexa Voice...
Why did it suddenly stop working?
the "pat answer" is the magic smoke leaked out. all electronics work on magic smoke, once it gets out of a device, the device wont work anymore. OK smoke comes from burned out devices. Point the remote at a digital camera and watch through the view finder, does the led in the remote light up? (you cant see it with the human eye) if so next step. plug the dongle into the TV, select the correct input and point the remote directly at the window on the dongle and try to operate the fire stick, if it works, you may need an HDMI EXTENSION cable (male to female) to move the dongle to a position where it isn't blocked from the view of the remote. Also, can you operate it from your computer using Google Chrome and the correct firestick extension? (incase the remote isn't infrared operated)
Apr 03, 2016 | Amazon Fire TV Stick
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
Apr 02, 2015 | Amazon Fire TV Stick
Accidently turned off blue tooth
Amazon Fire TV Stick Logo
41 people viewed this question
Top Amazon Televison & Video Experts
Andrew Taylor
Andrew Taylor
bigdawg7299
ray gallant
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
