Question about Sirius Kitchen Ranges
I want to know how to change the light in a Sirius sm950 850 range hood?
2 Suggested Answers
  • 37 Answers
SOURCE: how to change the light in technika range hood
Safety is important when is comes to replacing a light bulb of a range hood. The first thing to remember is to turn off power and allow lights to cool before proceeding.
home light
Posted on Jun 04, 2012
My Sirius Range Hood has two lights that take G4 Halogen bulbs. Is there a 115V bulb made for this application or is there something that converts the voltage to 12V?
These Halogen bulbs are inefficient, and run so hot that they often damage the reflector and bulb socket if they are left on too long. Fortunately there is an easy fix for this. At most stores that sell the exact replacement Halogen bulbs (Lowes, Home Depot and others) you will see a selection of LED bulbs on the same display rack that will fit into the same socket the Halogen bulbs use. It is IMPORTANT that you know the code number stamped on the base of your Halogen bulb AND its voltage because some Halogen bulbs are 12 volts and some are 110 volts. If you can't read the labeling on the bulb, look for the wiring diagram usually glued inside the range hood or look in your owner's manual. Once you know your Halogen bulb's code number, look at the packages that the LED replacements come in. There will be a list of Halogen bulb code numbers that the LEDs are meant to replace. The male sockets on these LED replacements will be shaped just like the sockets on your original Halogen bulbs so they will plug in easily. However, just like LEDs bulbs that replace the old incandescent bulbs in your table lamps or ceiling sockets, they have an electronic section included in there base to run the LEDs and it makes the LED bulb slightly longer than the much simpler Halogen bulb. For my stove hood it meant that the bulb would not quite fit into the reflector in the hood. I had to use a Dremel tool to remove a bit of the reflector to get a proper fit. The LED bulb is just as bright but runs SO much cooler and uses so much less electricity that now I can use the range hood as a night light in the kitchen. I never felt safe doing that with the two Halogen bulbs since they ran so hot that they were burning the fixture that held them in the stainless steel hood and were melting the wiring entering the socket base. This upgrade to your range hood is well worth the effort.
Nov 29, 2016 | Sirius Kitchen Ranges
We have sirius 900 built in. Lights (both) stopped working and apper fine upon inspetion. Fan works fine. I can also hear the light switch click every time switch is depressed. Help. Thanks.
You need to trace the path of the current (voltage) Start at the light and work backwards. Check for 110Vac at the socket. If its there you have a bad bulb, if not keep going backwards towards the switch until you find 110Vac. When you find it the problem will be in between the last 2 points you checked.
Aug 13, 2014 | Sirius Hoods SIU3 90 SS Island Range Hood
Sirius range hood SU 5 U1 - A4- H2 loud noise
Could someone translate espressonist's post into English? thanks
Nov 16, 2012 | Sirius Kitchen Ranges
We have a sirius model sut900w/su900m built in range hood and all the sudden nothing works on it. Never had a problem for three years. lights nor the fans will work. Is there something on it we should...
the fuse on the unit may have broke or the breaker for the unit ay have tripped, check the breaker and if thats fine check the manual to see if there is a fuse and where it is located. If it is the fuse you can get a replacement at your local hardware store.
Jun 17, 2011 | Sirius Hood Built-in Powerpack, SU900
Hello, have a sirius range hood 600-cu.ft./min of power, 4-speed fan, electronic controls, halogen lighting. its not working at all. press controls, nothing, power is going to it, checked that. what you...
Check for power in and out of the main control board...sounds like the main board has fired...if you have power going in, but none coming out then the board is bad..
heatman101
May 02, 2011 | Sirius Hoods SU3
I have a Sirius range hood SU3. It sound like the right side of the fan blades are off-balance, because it's making a scraping noise. It is starting to get annoying. I looked at it and I don't see a way to...
Yes, I am on my third motor in a SU 4/ Sirius is brutal to deal with. All of the motors are **** and they are always back ordered. here in Canada the distributer change around 2008. They are through Maroline and a crappy company to deal with unlike the othe people in Oakville. Service sucks for such an expensive and beautiful stainless hood. Good luck and the motor does come off...
Jan 05, 2011 | Sirius Hoods SU3
Sirius hood fan maintenence
I do just spray with degreaser first then rinse off.
Then you can wash in the machine without worry of clogging up the unit.
Feb 27, 2010 | Sirius Hoods SIU401-22 SS Island Range...
Kitchen Ranges Logo
47 people viewed this question
Top Sirius Kitchen Ranges Experts
Thomas Perkins
Thomas Perkins
Zeagle
Level 1 Expert
Are you a Sirius Kitchen Range Expert? Answer questions, earn points and help others
