Question about Optics
Whatis the bright star adjacent to the moon?
Jan 1st 2017; what is the object closest to the moon right now???
  • Optics Master
  • 5,412 Answers
Probably the planet Venus
Posted on Jan 03, 2017
Seeing the stars
The stars will always be "points in the sky" no matter what telescope.
The stars should be sharp, focused points in the center of view (more blurry towards the edges because of the stock eyepieces and the fast telescope mirror) if not, the telescope may need collimation. (look at instructions and/or search online. Plenty of instructions on the net.)
  1. Get Stellarium or another fine astronomy program
  2. During the day, point the telescope at a part of the landscape about 100 yards away.
  3. Use the lowest power eyepiece (highest number) in the focal tube.
  4. Center the landscape object in the telescope.
  5. Align the finder scope so that it points exactly where the main telescope is.
  6. At night, leave the scope out to reach thermal equilibrium (about an hour for small reflectors and refractors)
  7. If the scope is on a EQ mount, polar align.
  8. Point the finder at the moon. The moon should be in the main scope also.
  9. Practice finding the moon before you start on the planets
  10. Once you are comfortable with the moon and planets, you can go for the deep sky objects
Dec 23, 2012 | Optics
Cant see anything through the view finder
1. During the day, use the 17mm eyepiece on a object outside (telephone pole, water tower, etc) then align the finder to what you see in the scope.
2. Put in the 7.5mm eyepiece and fine align the red dot finder.
3. At night, point the finder at the moon (less than half moon or the image is too bright without a moon filter) Use the 17mm eyepiece.
4. Once you see the moon, switch to the 7.5mm lens and enjoy.
5. Download Stellarium or any free astronomy software and see what is in your sky tonight. Your scope should be able to see Jupiter and its moons easily.(Saturn, Mars and Venus when the time is right) Open clusters like Pleiades will be nice is this fast scope.
5. If stars are not sharp, you may need to collimate the scope. Look online for general instructions.
Nov 14, 2011 | Optics
Hi ive got a galaxsee tasco telescope but im having trouble seeing anything at night, i've took all the caps off lined up on a star but its just pitch black can you help thanks.
1. During the day, point the scope towards an object and align the finder scope to the telescope.
2. First object at night should be the moon. it will verify your finderscope alignment and you should have a clear view of the moon.
3. Use your lowest power eyepiece (largest number in mm) and point the finderscope to a star. The star should be in the center of the eyepiece.. If not, adjust the finder until it and the scope are centered.
4. You can use your higher power lens on the star nd it should still be in the FOV (field of view)
5. Scope may need to be aligned (collimated). Instructions on this should be included with the scope
Mar 10, 2011 | Tasco Galaxsee 46114375 (375 x 114mm)...
Hi, a few days back I purchased Nexstar 4SE. I set it up exactly how it says in the manual still I cannot see any magnifying views from the eye piece. While aligning the telescope I can find the moon from...
Stars will always appear as points. It is not possible to magnify them enough to see them as disks because they are all extremely far away. A telescope will however show you stars and other objects that are too dim to see with the naked eye.
You will be able to see the planets as disks, and even features on the planets, such as the bands on Jupiter, the rings of Saturn and the phases of Venus, and also moons around some planets. There are other objects that will show more detail when magnified, such as nebula. You will be able to see a lot of craters and other detail on the Moon.
Your problem is simply that you are not pointing the telescope at these objects. This seems to be one of those telescopes that "automatically" finds objects, but these so called "go to" scopes only do this when they are set up properly. I can't say what step(s) you have missed, but clearly even if the scope thinks it is pointed at the moon, if you can't see the moon, it is NOT pointed there. The Moon will fill the field of view even with the least powerful eyepiece. If you are seeing stars as points, then the eyepiece is focussed and working properly.
Jan 13, 2011 | Celestron NexStar 4 SE Telescope
Cannot get it to align correctly, followed the instructions and it could not even find the moon
Most goto scopes must 1st have the tripod level using a bubble level, and some must be TRAINED during the day time on a distant object.
Time, Date, and Site must also be correct. The scope may also have a HOME position.
Usually you need to center TWO or THREE alignment stars before it knows the sky.
Did you do all of this? Read my TIPS on goto scopes on my profile page.
Aug 18, 2010 | Konus Optics
How to use telescope at night?
Many people have the same problem-- with these small telescopes you are stuck with seeing only the moon, and several other planets, and maybe a few bright star clusters.
These are all TINY objects (except for the moon).... when you look through the telescope you are looking at a section of sky about the size of your fingertip held at arms length-- the scope must be pointed DIRECTLY at the object. Practice on the moon first-- and then try to find Saturn which is up in the sky right now-- it looks like a dim (slightly yellow) star.
Download a free star chart at www.skymaps.com ---
Apr 01, 2009 | Edu-Science (10166) Telescope
Red dot finder scope
Simple-- you can also do this during the day on an object at least 100 yards away-- but at night; get the moon centered in the eyepiece and without moving the telescope center the red dot on the moon. This will get you almost aligned-- then put a bright star in the eyepiece and readjust the red dot to center the star.
Jan 09, 2009 | Bushnell NorthStar 78-8831 (525 x 76mm)...
I Cant see ANYTHING.
Put the lowest magnification eyepiece in the telescope-- it's the one that has the LARGEST number written on it.
During the daytime, go outside and point the telescope toward a distant object at least 100 yards away and practice focusing the telescope--- turn the focus know very slowly. Do this until you learn how to get a clear view of the distant object.
Once you have it focused wait until dark --- don't turn the focus knob. Your first sky object should be the moon or Venus -- which is the BRIGHT "star" in the west after dark....
Dec 29, 2008 | Vivitar (1607225) Telescope
Hardin Optical Deep Space Hunter model DSH-6
your telescope appears to be a newtonian reflector on a dobsonian mount. This type of scope is basically a point and shoot design, simplicity itself and many experienced astronomers swear by them, for there ease of use, set-up time etc.
The number 6 in the model number denotes the aperture (size of mirror) in inches. This is a good starter scope (much better than these small scopes that boast 525 X magnification) and with it tou will be able to clearly see Jupiters four main moons and the planets cloud belts. You will be able to see Saturn and it's ring system. Many nebulae, star clusters etc will become visable, that were invisible before.
Getting started with this kind of scope is pretty easy even for an absolute beginner. Set up the scope on a flat even surface, putting it all together should be self-explanatory. Insert the lowest power eyepiece (Usually the one with the biggest lens, and the one with the biggest number i.e. 40mm) and begin by pointing the open end of the scope at a bright object in the sky. To get you going with a bit of a buzz, I suggest Jupiter. Jupiter rises in the SE at 20.50, and is due South at around half past midnight, Look for a bright star that doesn’t twinkle to the right of the moon at about midnight, and that’s Jupiter!
Whilst looking through the eyepiece, carefully move the scope back and forth, up and down in the general direction of the planet. Remember, you are only looking at a very small part of the sky, probably about the size of a full moon.
It is unlikely your scope will be in focus at this stage so what you will find will probably look like a doughnut. When you find this “doughnut” you will need to focus. Adjust the focus knob until you see a crisp image of a small disk. If you are in Europe, you will see three bright moons (two on one side and one on the other) the fourth is hard to see tonight, but if you are lucky, you may glimpse a view of the shadow of this moon (Europa) as it crosses the disk. On the East coast of the US, you will also see three moons clearly, the fourth, Ganymede. Is still in Jupiter’s shadow at half past midnight, but by 1pm, it will become visible as it moves out of the shadow.
Keep looking for Ganymede during this half hour, it makes interesting viewing, and gives a sense of realism and motion to the whole event.
Try using different eyepieces as you become more accustomed to your scope, everything you see is upside down and back to front. Using different eyepieces will require re-focusing, but with a bit of practice, it will become second nature.
Finally, adjusting your finder scope. You will notice that the finder is held in place with two (sometimes three) adjustable screws. It may be best to set the finder scope up in the daytime. First find a distant object in the main scope (the further the better) a chimney pot on a distant roof etc. Then using the adjusting screws, centre the same object in the finder. It’s a bit fiddly at first, but you will get the hang of it. Then when night time comes, finding celestial objects is much easier. First locate the object in the finder scope, centre it, and the object should be in view in the main scope.
Hope this helps to get you going.
Kind Regards….Dave
Jul 16, 2008 | Hardin Optical Deep Space Hunter 6 (240 x...
Optics Logo
41 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
