I have a Harmon Accentra FS. After replacing pots on control board now I have 3 flashing status lights. Not able to clear these. MW
SOURCE: fs-1030
This is a Thermostate problem. You have to reset thermostate or replace the fuser unit your problem will resolve.
Posted on Jul 28, 2008
M2Tech1
  • 313 Answers
SOURCE: kyocera fs-1920 printer fault
if the machine is starting up and you just replaced the toner cartridge make sure it is seated properly also did you shake the cartridge slightly before fitting sometimes the cartridge can compact the toner and it doesnt agitate to the dev unit properly. check also if the dev unit has been reset properly and the lever set in place..
Posted on Jun 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: 3 flashing light....Aire-Flo furnace AF80MPA100B5A
That control board is several hundred dollars. If I may make a suggestion, take a jumper and when the inducer fan starts, jump out the pressure switch. If it starts, it's not the board but a bad switch, hose or blocked exhaust vent.
Posted on Jan 15, 2010
firesnake09
  • 2923 Answers
SOURCE: status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Posted on Feb 14, 2010
ladywinn
  • 5138 Answers
SOURCE: I have a Mitsubishi WD-52327.
Replace the Lamp P/N 915PO20010 if it has never been replaced.
Mats Electronics has them for $99.00 1-800-628-1118
Posted on Feb 15, 2010
My status light blinks 7 times on my pride scooter how do I fix it
Hi 7 flashes ( SPEED POT ERROR ) possible speed control pot ::: wig-wag. control lever ,is ,faulty or it's possible the computer (CONTROL BOX ,) is Faulty...Get in touch with pride mobility ,..www.pridemobility.com.au .. Cheers
Jan 14, 2017 | Pride Health & Beauty
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
I have a Amana unit Model# PGA60C1152F that has a blinking light on the control board it blinks 4 times. That heat will come on then go off but the blower nevers comes on.
look on the inside of the door that you took off and there should be a diagram and on that there will flash code that will tell you what 4 flashes means.i think it is a flame rollout or high limit.
Nov 16, 2012 | Amana Heating & Cooling
Status light beeping once then twice everything works but not driving was going allright befor and fully charged
Hi. This fault code is normally associated with a faulty speed lever. Could be a faulty pot, broken wire on the pot, or a plug fallen off the circuit board.
This fault code is normally displayed by a Curtis controller, if your machine has a different controller, it might mean a different fault has occured.
Good luck. Neil.
Jun 08, 2010 | Pride Mobility Products Go Go Ultra X 3...
Status indicator flashes 3 short times, then one long red flash
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Flashing message indicator light is on but there is no message
from operators dss hit mw key then the ext you are trying to clear
May 19, 2009 | NEC 80570 Telephone
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Fs-1030
Jun 10, 2008 | Kyocera Mita FS-1030D Laser Printer
Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Nov 19, 2007 | Whirlpool GHW9200L Front Load Washer
23 people viewed this question
k24674
