Step 4 full-automatic searching for code, what equipment response am l suppose to have?
  • kakima Jan 02, 2017
    Hi Nancy Salvatico, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model equipment are you asking about?
My photocopier sharp AR 5516 is showing H4, what is the solution?
There's an earlier response to this question on fixya in Dec 4, 2012. Search "sharp ar5516 error code h4". It's the third hit down.
Jul 09, 2015 | Sharp Office Equipment & Supplies
Tip
Programming remote control
DIRECT CODE ENTRY
Step 1:Press and hold the device key (TV, VCR, SAT, etc) you wish to program. The illuminated ON/OFF key(*) turns on and remains on. If you release the device key at any time during theDirect Code Entryprocedure, the illuminated ON/OFF key blinks 4 times, and the process is exited.
Step 2:While holding down the device key, use the number keys (0-9) on the keypad to enter your equipment's code. While you are pressing the numbers, the illuminated ON/OFF key turns off.
Step 3:After the 4th number is entered, the illuminated ON/OFF key turns on. At this time, release the device key. If the illuminated ON/OFF key turns off, you have entered a valid code and have followed the correct procedure. If you enter a code that is not in the Code Lists or you do not follow all of the correct steps for Direct Code Entry, the illuminated ON/OFF key blinks 4 times when the component key is released - an indication that a programming error has occurred. In that case, repeat the process from Step 1 and try the next code in the list.
Step 4:To confirm that remote is programmed with the correct code for maximum functionality, test it. If some of the features of your equipment do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions as different codes can provide different levels of functionality.
* some models like the RCR450 have a LED indicator light in place of the illuminated ON/OFF key.
AUTO CODE ENTRY
If your component's brand is not listed in the code tables, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Auto Code Search method below. The remote will cycle through all of the codes, in the event that your code is listed under another brand. TheAuto Code Searchmethod may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand appears in the CODE LIST You should try first theDirect Code Entrymethod described above.
Step 1:Manually turn on the device you want the remote to control (TV, VCR, DVD, cable box, etc.).
Step 2:Press and hold the device button (TV, VCR, DVD, etc.) you wish to program. The illuminated ON/OFF key turns on and remains on.
Step 3:While holding the component button down, press and hold the ON/OFF key. The illuminated ON/OFF key turns off.
Step 4:After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 5:Release both keys. The illuminated ON/OFF key remains on.
Step 6:Press and release the PLAY button, then wait 5 seconds to see if your component turns off. If your component does not respond, continue to press the PLAY key every 5 seconds until your component turns off. Each time you press the PLAY key, the illuminated ON/OFF key blinks and a block of ten codes are sent to your component. This process continues until all of the codes have been searched. If your device has not turned off after all codes have been searched, the illuminated ON/OFF key blinks 4 times and turns off. The Auto Code Search Entry method is exited.
Step 7:When your equipment turns off, you know'll that the correct code is in the last block of 10 codes sent. Press and release the REVERSE key, Wait 2 seconds to see if your component turns on again. If your component does not respond, continue to press the REVERSE button every 2 seconds until your component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE key is pressed, the illuminated ON/OFF key blinks.
Note:If you accidentally press the REVERSE button after your device responds, press and release the FORWARD key. Wait 2 seconds to see if your component turns off again.
Step 8:Once your component turns on, you have found the correct code. You must save the new code by pressing and releasing the STOP key. The illuminated ON/OFF key turns off.
Important:You must press the STOP key to save the code or the correct code will not be stored!
MANUAL CODE SEARCH
Step 1:Manually turn on the component you want the remote to control and keep the remote pointed at it.
Step 2:Press and hold the component key (TV, VCR, DVD, etc.) you wish to program. The LED indicator light turns on and remains on.
Step 3:While holding the component key down, press and hold the ON/OFF key. The LED indicator light turns off.
Step 4:After holding down both keys for 3 seconds, the LED indicator light turns back on.
Step 5:Release both keys. The LED indicator light remains on.
Step 6:Press and release the ON/OFF key repeatedly until your component turns off. Each time you press the ON/OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
Because there are so many codes, you may have to press the ON/OFF key many times - possibly up to 200 times.
Step 7:Once you have found the correct code, you must save the new code by pressing and releasing the STOP key.
CODE RETRIEVAL
If you used one of the Code Search methods above to program your remote you may want to record the codes for future reference. Retrieving the actual code and writing it down will save you time if you ever need to program the remote again (when you change the batteries for example). If the codes are recorded, you can use the Direct Entry method to reprogram your remote to control your device, which is quick and easy.
Step 1:Press and hold the component key (TV, DVD, etc.) whose code you wish to retrieve. The illuminated ON/OFF key turns on.
Step 2:While holding the device key down, press and hold the INFO key. The illuminated ON/OFF key will turn off.
Step 3:After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 4:Release both keys. The illuminated ON/OFF key remains lit.
Step 5:Starting with the number 1 key, press and release each number key on the keypad in the following order: 1 to 9, then 0. The number that causes the illuminated ON/OFF key to blink is the first number of the code.
Note:
TV codes begin with the number 1
VCR codes begin with the number 2
DVD codes begin with the number 3
Satellite receivers and cable boxes, codes begin with the number 5.
Step 6:Repeat step 5 until you have retrieved all 4 numbers in the code.
Step 7:After the fourth number is retrieved, the illuminated ON/OFF key blinks briefly, then turns off.
Note:To exit theCode RetrievalMode, press and release the "GO BACK" button at any time.
For codes check the following link
Electronics Equipment Repair Center
on Jan 26, 2015 | RCA Televison & Video
Tip
How to program your Dish Network remote to your tv
Find your Codes for your devices here first: http://www.dishnetwork.com/customerService/troubleshooting/nhagent/default.aspx
The follow these directions:
OK, I understand that you need help programming your remote control to a TV or other equipment.
Note: After this procedure is started, if a button is not pressed within 20 seconds, the remote will end the procedure automatically. Simply start over again.
Step-by-Step Procedure // Step 1 of 6
Click on the following link to find the remote codes for your brand of TV, VCR, or other equipment. Note that codes for each TV brand depend on the remote type.
Step 2 of 6
Press and hold the correct Mode (TV, VCR, or AUX) button for about six seconds until all mode button backlights come on, then release.
Step 3 of 6
Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
For AUX mode ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device.
Step 4 of 6
Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Step 5 of 6
To verify the code works, press the mode button. Try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
Step 6 of 6
If the remote still does not operate the device, perform the Power Scan.
If the remote still doesn't operate equipment, it may not be compatible with that equipment.
on Dec 02, 2009 | Televison & Video
How do I program the remote to my tv
HI,
DIRECT CODE ENTRY
FOR CODES CHE THE BELLOW ADDED LINK
AUTO CODE SEARCH
If your component's brand is not listed in the code tables, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Auto Code Search method below. The remote will cycle through all of the codes, in the event that your code is listed under another brand. TheAuto Code Searchmethod may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand appears in the code list you should try first theDirect Code Entrymethod described above.
MANUAL CODE ENTRY
CODE RETRIEVAL
Note:
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE 4 DIGIT CODE FOR...
Electronics Equipment Repair Center 3 DIGIT RCA UNIVERSAL REMOTE CODE FOR...
Electronics Equipment Repair Center RCA UNIVERSAL REMOTE CONTROL 3 DIGIT...
Jan 25, 2015 | RCA Televison & Video
Need code for Magnavox TV for GE 24116-B remote
Found a link to download the manual for the remote. The instructions walk you through doing an automatic code search. If that is unsuccessful, there is a web address that is supposed to give you a full list of all the codes.
http://files.remotecentral.com/view/290-461-1/ge_24116_4-in-1.html
Dec 21, 2014 | GE Televison & Video
How do I program my tv remote
HI,
DIRECT CODE ENTRY
Step 1:Press and hold the "CODE SEARCH" button ("CODE.SRCH" for RCU500).
Step 2:Press and release the device (VCR, TV, Cable etc.) button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 3:Enter the 3 digit code number
Step 4:Release the "CODE SEARCH" button.
Step 5:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test.
CODE SEARCH
If you cannot locate the code for your device, try thecode searchmethod below:
Step 1:Turn on the device.
Step 2:Press and hold the "CODE SEARCH" button.
Step 3:Press and release the VCR, TV, Cable or Audio button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 5:Press "ON/OFF" (or "POWER" for RCU500) repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button up to a hundred times (at a rate of once per second) if your code is towards the end of the preprogrammed list.
Step 6:When your device shuts off, press and release the "ENTER" button.
Step 7:With your device on, press another button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test, and if it does not function correctly repeat steps 1 through 6.
CHECK THE LINK FOR CODE
Sep 27, 2014 | RCA Televison & Video
I need the control remote code
irect Code Entry for GE remotes with 4 digit codes
The following is a short tutorial on entering the codes on GE 4 digit code universal remotes. See also this page for general GE remote code entering instructions!
Step 1: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 2: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink, then stays lit.
Step 3: Enter the 4 digit code for your device. After a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes!
Step 4: With your device on, press "CHANNEL UP" or "CHANNEL DOWN." If the device responds, no further programming is required. If some buttons do not operate your device, try one of the other codes for your brand. Note, when all codes have been searched the red indicator flashes rapidly for 3 seconds.
Code Search instructions
If your device does not respond to any of the codes listed with your equipment, or your brand is not listed, try the following steps:
Step 1: Manually turn on the device to be controlled.
Step 2: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 3: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink once, then stays on.
Step 4: Press the "CHANNEL UP" button repeatedly until the device to be controlled changes channel. The red indicator will blink, then stays lit.
Step 5: Press and release "MUTE" button to install the code. The indicator light goes off.
Generally it's best to store VCR codes under the VCR button, cable codes under CBL, and so on. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter any VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Sep 13, 2013 | RCA DRC230N DVD Player
Lg 50pc3d plasma
Procedure is
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
Jul 07, 2013 | Universal Remote Control Televison & Video
I can not program my universal RCA remote to my JVC DVD player. I know it can be done, because it was programmed before. I do not what I "hit" or"pressed" to make it stop working....I...
If you cannot locate the code for your device, try the code search method below:
Step 1: Turn on the device.
Step 2: Press the "CODE SEARCH" button until the indicator light illuminates, then release.
Step 3: Press and release the VCR, TV or Cable button. If programming for AUX, press and release AUX button first, then press the device type to be programmed.
Step 5: Press "ON/OFF" repeatedly until the device turns off. Note that because there are so many codes, you may have to press the "ON/OFF" button a few hundred times if your code is towards the end in the list.
Step 6: When your device shuts off, press and release the "ENTER" button.
Step 7: With your device on, press a frequently used button like "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN" to test. If it does not function correctly, repeat steps 1 through 6.
Auto Code Search Step 1: Turn on the device you want the remote to operate.
Step 2: Press and hold the "CODE SEARCH" button until the indicator light illuminates, then release.
Step 3: Press and release the device key that corresponds to the equipment you want the remote to operate (TV, VCR/DVD or DBS/CABLE etc.). The indicator light blinks once and then remains lit.
Step 4: Aim the remote at the device and press the ON/OFF key once. The remote automatically sends every code for the specified component one at a time, with a a few seconds delay between each code. Keep the remote aimed at the component throughout the process.
Step 5: As soon as the component turns off, you must press the "ENTER" button immediately for the remote to store the correct code. If you don't press "ENTER" within a few seconds, the remote will send the next code in the list and you will have to start over from Step 2.
Step 6: Use Code Retrieval described below to identify the code for your device for future reference.
Code Retrieval If you used one of the "Code Search" methods to program your universal remote control, follow the steps below to find out which code is compatible with your device. Finding the actual code and writing it down will save you a lot of time if you ever need to program the remote again.
Step 1: Press and hold the "CODE SEARCH" button until the indicator light turns on, then release.
Step 2: Press and release the device key that matches the equipment's code you are retrieving (TV, VCR/DVD, DBS/CABLE, etc.). The indicator light will blink once then remains lit.
Step 3: Press and release the "CODE SEARCH" key. The indicator light will turn off.
Step 4: Starting with 0, press the number keys in order (0-9) until the indicator light blinks.
Step 5: The number that causes the indicator light to blink is the first digit of your code.
Step 6: Repeat Step 4 until you have retrieved all 3 numbers of your code.
Nov 04, 2010 | RCA 4-Device Universal Remote
I lost the code to the ge universal remote jc024
hi...
From this website you can get the for your remote
http://www.jascoproducts.com/support/universal-remote-codes.asp
follow the steps to set up the remote
Method 1
Jul 20, 2010 | Universal Remote Control GE174Universal...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
