Question about Kenmore Refrigerators
My kenmore elite model 795.72053.110 is not dumping ice. The ice is there but it is not dumping it in the bin. How do i fix this
  • 489 Answers
SOURCE: Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Posted on May 11, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
I am an attorney near Philadelphia who is considering initiating a class action against LG related to the defective design of their ice maker. I have clients in different states who have had problems that LG fixed, but the problems re-occurred after the warranty expired. I've been advised by mechanics that leaks are inevitable based on the design. Apparently this is a design that LG had used years ago but had discontinued for a while because of leak problems. I'm usually on the defense side of product liability cases, but this seems to be a common defect. If you are interesed in such a suit, feel free to contact me at corrlaw@verizon.net. Law Office of John A. Corr, (610) 482-4237.
Posted on May 15, 2009
  • 103 Answers
SOURCE: frigidaire not dumping the ice
Hi: Dumping the ice is the start of the ice making timer. Before you replace the ice maker... Set the freezer one setting colder. The ice maker wont make ice if the freezer is not at zero degrees F. Just because things are frozen in it dosn't mean it is at zero. This happens a lot in the summertime. After resetting the temp don't open the door every hour to see if it makes ice as you will just dump the cold air out. Listen for the ice to dump, give it 24hrs. I hope this helps, Jeff
Posted on Jun 07, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
Model # 253.7033 My ice maker has stopped mid cycle.
Your heater finally went out in your ice maker it will have to be replaced it would be easier just to replace the entire ice maker assembly which it a ten minute fix.
Feb 28, 2014 | Kenmore 73503 Stainless Steel Bottom...
I have a Kenmore side by side Model 25351694100 that makes ice great, but will not dispense. I hear things moving, but no ice comes out. Can I fix this, or do I need a pro?
Usually when this happens its becasue the auger, located inside the ice bin itself, has came loose,or popped out of place. If you have the kind of ice bin that slides in, pull it out and dump th ice. You'll see a long, metal twisted rod that runs front to back. At the back side of it is a white cap that the rod attaches to and mounts in a hole in the ice bucket itself. Sometimes you can readjust it and it will work but sometimes you may have to buy a new bin if any of the plastic is broken.
Nov 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Elite side by side wont distribute ice
you may try dumping the ice and rinseing the bucket make sure door switch is closed.
Oct 16, 2009 | Refrigerators
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stoped working
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
152 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
