Question about Behringer Music
Behringer B205d...Is it worth fixing if speaker voltage was used in input? Main board burned out I suppose. Mfg date is 2009. No power now, was smoking from overload when it happened.
    Top Expert:
  • Behringer Master
  • 3,113 Answers
It's probably not cost effective to repair it' Check the horn driver and the raw woofer to see if they are still good, and if so retain then as spares.
Posted on Jan 03, 2017
SOURCE: Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
i have a problem i need to know all about this power supply what the output is and the input and so on everything thats writen down the the adaptor
Posted on Jul 09, 2010
  • 5603 Answers
SOURCE: On stage live...I want to
Oh my... the EMX512SC does NOT have any "sub busses" there fore there is no way to just hear YOUR vocals where there are other vocal present. The way to connect this is to run YOUR mic into the B205D and then run the line output that is intended to run to other B205D's from the B205D into a channel of the EMX512SC.
Posted on Jun 25, 2011
  • 5603 Answers
SOURCE: I want to connect my Mackie mixing board
Use the main left and right... the CR outputs are INTENDED for running control room monitors.
Posted on Jul 05, 2011
lucastroo
SOURCE: how do i get parts for behringer b215d my power ic is burn out
Regards, urgent help.
I have a powered speaker Class D, and the PWM isdead. change the IC 3525, is controled by a NE555 which is shutting down. works when connected to a higher voltage 150v, but turned it off, I think by overheating. I already changed mosfets, and ICs. I think that may be some component failure is triggering the protection, someone could help me. I'm a musician and I depend on this car for my livelihood. Thanks
Posted on Nov 23, 2012
  • 3113 Answers
SOURCE: I have a Behringer nu4-6000 amp that I am trying to connect Peavey 215 speakers (2-1/4 inputs). How do you connect the 4-pole cable that is bi-amping from d Behringer speakon, 1/4 only uses 2 cables.
That will depend on what you want to end up with. Peavey has made a number of 2-15" cabinets, but most have 2 1'4" input jacks wired in parrallel. the easiest way would be to use a 2 pole Speakon wired 1+ 1- from the amp to a 1/4" phone jack. 1+ would be hot and 1- would be ground. I see that two of the Behringer outputs (B ad D are wired that way.
Posted on Mar 14, 2016
Power light is on but no speaker output?
Disassemble it enough to get to the speaker to check for continuity. If it's blown, replace it, If not, the amp board is probably blown and needs to go in for repair.
Mar 08, 2016 | Behringer Eurolive B205D Active 150-Watt...
Powering on and off
Like as not, Behringer is a disposable brand once the warranty (which does not cover wearing parts like pots and faders which wear out quickly and are not worth replacing due to the design in most cases)
We normally sell behringer kit if it still works just before warranty expires.
Feb 13, 2014 | Behringer Eurolive B205D Active 150-Watt...
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
How do i get parts for behringer b215d my power ic is burn out
Jan 06, 2012 | Behringer B215D Powered Speaker (550 Watts...
Just bought. New b205d power is on but no sound
These are a nice unit... just bought three of them that were dead... I have repaired one so far. I assume you mean the blue LED is on indicating power is on. What I want you to test is if injecting signal on the BACK of the unit jack (power amp in) will create sound. If it won't then better exercise your warranty. The one unit I have completed repair had a bad 15 volt regulator in it... the second that is almost fixed somebody had blasted the input circuits... probably connected to a speaker output... don't do it... these are LINE and MIC level units. If you need to tap off a speaker output, use a DI box with the unit. The third unit I have not received yet. Drummer used the repaired one as monitor last night and was impressed with the power this unit has.
Jul 22, 2011 | Behringer Eurolive B205D Active 150-Watt...
On stage live...I want to use the B205D as a personal monitor...the band uses a Yamaha EMX512SC 8 powered mixer on stage...What would be the correct connections to hear only my vocals in the B205D monitor...
Jun 24, 2011 | Behringer Active 150Watt PAMonitor Speaker...
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
Pmp3000 problem power supply.ic circuit problem.number series ic circiut..
I have a PMP5000 that I had to resurect. I had to trace out the power supply to repair it.
I can give you hint: First, a small supply runs directely from the line and generates some of the small voltages. While this starts, the main power caps are charged through limiting resistors. The main switcher is brought online and if the power amps acheive balance, then a relay connects the speakers and shorts the limiting resistors.
This is what is in the 5000 and I suspect the 3000 is similar.
In my 5000, there was arcing at one side of the power amps. The board was burned and three power fets fried. Cancer of burned board had to be carved out and traces replaced by hardwiring.
In addition, the limiting resistors were blown open, both main switching transistors were blown and 4 small driver transistors (surface mounted) and several diodes AND a switching regulator chip (surface mounted).all fried/
Hint: When restarting the unit, put a 150 watt light in series with one of side of the power input to limit the current in case you did not get all the dead bodies out.
This is a class "D" amp which drives PCM waves into a filter which is then the audio output. It is much more efficient thaan a linear amp.
Dec 24, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
I Have a behringer pmp3000 16 channel mixer amp. the problem i have is that one side is weaker than the other considerably. using the desk in stereo mode. tried and checked leads and speakers but alas it...
As a test, plug ONLY into the RCA stereo inputs and test for equality. Have no other connections when testing other than the speakers. Make sure the Speakon cables for the speakers connect correctely and that the
This unit has some TRS inputs and one must use cables designed for that. Often a person may plug a mono into a TRS inout and the barell of the mono grounds out the ring of a TRS connector. Make sure the slide switch is clear up to Main L and Main R position.
The amps in these units are "class D" which are like the Peavey DECA amps, that is are switching type with filter. They are very efficient pwer wise. They usually are all there or totally dead, not just weak.
Make sure you do not go below the load resistance they specify. (Usually 4 ohms)
The power supply is a switching regulator and has lethal voltage present so use caution if you open the unit. They are hard to work on and Behringer doesn't supply schematics. I had to trace out the circuitry in a PMP5000 I repaired.
Aug 18, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
