Question about Electrolux Washing Machines
I have an Electrolux Ultrasilencer. It cuts off after 10-15 minutes of use. Any suggestions?
2 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: I have an Electrolux Ultrasilencer Deepclean
Good day!!!!
that problem and faulty codes is cause of overloading due to difficult spinning of motor that usually cause of lock on lubrication...Please try oil the motor...
If you have any clarification and query regarding my solution...Just add a comment and I response you as soon as I read the comment..
Thanks for using fixya...
Posted on Aug 12, 2011
How to dissasemble
This is a general response but I have found most of them to be the same way. Take off all panels and access doors that you know come off. On the bottom or side of the unit you will see deep hole molded into the body. If you flash a light down you will see a screw head with a Phillips head or Torx bit. You will need a long screw driver with that bit on it or an extension that will fit. There will most likely be about 6 of those to remove.
May 21, 2014 | Electrolux EL7060A UltraSilencer DeepClean...
Electrolux icon duel fuel range racks red light wont stop flashing even though I removed all racks, so oven will not start self clean cycle
Good Morning Andrea,
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Mar 23, 2014 | Electrolux Icon E30df74gps 30" Pro-style...
Cord won't stay out, it keeps going back in
when pulling the cord out, it should 'keep' it that spot if you pull a certain direction, cant recall if it is up, or down, left or right, and pulling it opposite direction releases the cord again
Mar 10, 2013 | Electrolux EL6984A UltraSilencer Green...
Green canister lid wont close
http://smallappliances.electroluxusa.com/en-US/Customer-Support/
download free your instr manual and see your problem lid why not close, go to the section troubleshooting.
God bless you
Sep 27, 2012 | Electrolux Ultrasilencer Green Canister...
How to clean a washable electrolux filter
Hi There,
Ok so i am going to assume you are talking about an Electrolux filter that is basically a rectangle shape with a hard plastic outer and folded corrugated filter material in the middle. The link I put to Electrolux filter would be a good example. Basically I would caution you against washing it. I know the packaging says that it is washable but what I have found is that the pores of the filter material are too fine for water to pass through. What will happen is that the vacuums suction will wedge tiny bits of dirt and dust in the pores and water will not necessarily flush it out. What is far more likely to happen is that it will wash out a fair amount but leave a portion in the filter to set and therefore continue to block suction.
You are better to use an air compressor or simply tap the filter out on a piece of newspaper and change it every year or so.
Of course if your filter is more like a Electrolux UltraActive filter which is basically foam then you simply rinse it out like a kitchen sponge and make sure it is bone dry before putting back in the machine.
Jun 26, 2012 | Electrolux Ultrasilencer Green Canister...
How do I take apart my electrolux ultrasilencer green vacuum to fix the retractable chord?
I would not recommend doing that. Take it to your local vac shop. They may or may not be willing to repair it. These machines were not built to repair. They are considered disposable. I have repaired these at my store but it is a very tedious task to get it apart without breaking all the tiny plastic tabs. You should give the local shop a chance before trying it yourself. They are better equipped for it.
Jan 08, 2012 | Electrolux EL6984A UltraSilencer Green...
I have an electrolux ultrasilencer washing machine. The display says "door not closed". The door is definitely closed. I switched it off for a few hours, switched it back on and have same...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 04, 2011 | Electrolux Washing Machines
My electrolux ultraone keeps cutting out after a couple of minutes - there are no lights indicating filter or bag?
This is not an Electrolux Lux 7000. Totally different companies.
However, check the hose for clogs. Drop a coin down one end and lift so it should drop out the other. If it doesn't, there's a clog that needs cleared. This can often be done by pushing it out with a broom handle.
Jan 26, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
