Question about Cameras
High RDW SD count mean
High RDW and RDW-SD indicate
  • Cameras Master
  • 5,412 Answers
To what make and model of camera does your query refer, please ?
How do I get the blood test results
Please ask this the lab you were. Not Fixya. we try to answer questions, but don't do blood tests.
Check the URL on top of the page, before you press post or send.
Jan 28, 2015 | Cardiochek Portable Blood Test System
What is deviation standard
The standard deviation is a measure of how "tight" the samples are distributed around your mean.
In layman's terms, a small standard deviation indicates that most of your measurements are in the vicinity of the means; a large standard deviation corresponds to readings that are all over the place.
You could also say that the smaller the SD, the more your mean is representative of the data set.
For a better explanation, just look up Standard deviation on Wikipedia!
May 03, 2014 | Audio Players & Recorders
What does it mean when the LCD says full but the SD card is empty.
I just fixed this problem on my new A-5. I had to take out the SD card, put it in my card reader and reformat the card on my computer. I just put it back in my A-5 trail camera and now it works and is counting down like it's supposed to.
Sep 14, 2013 | Moultrie A-5 Game Camera
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
We use NEC MT1065 and just replace its lamp but it still won't switched on (lamp indicator led is red). How can I reset it ?
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, if your old lamp has only had the reflector replaced then it will make no differance because the chip tells the projector weather or not to power up depending on the hours its counted, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention, just as an added note, a solid red lamp indicator light means that the lamp has expired, if its flashing red this means its nearing the end of its life, if the status indicator light is flashing then there could be another issue, by counting the flashes you can reffer to the manual in the troubleshooting section to diagnose the fault, I know this is very late, but anyone else reading this may find it helpfull.
Nov 29, 2010 | NEC MultiSync MT1065 Multimedia Projector
Rev count for 2009 corolla pro. goes up when engine starts even when the car is not moving. Is that normal?
High idle indicates that the engine most likely has a vacuum leak. This could be due to many causes; cracked hose or hoses, bad gaskets..ect. Hard to say exactly without more info, but you can open the hood and inspect the vacuum lines for damage or cracks. It is a 2009, so it probably is not something major.
Jun 09, 2010 | 2009 Toyota Corolla
What is activation key for download accelerator plus (dap94)
Try this key
3177-6353-RDW-JJGQD-10 or 3177-6353-RDW-JJGQD-10
Jun 06, 2010 | Computers & Internet
Air bag light
It means that there is a problem with your air bag. It should be blinking a code. Count the blinks. In otherwords it should blink twice, pause and then blink 7 more times indicating a code 27 which would be a burned out bulb on PAD. Count blink code and the google your truck year and air bag code and then the code and see what the forums are saying about it and what to check.
Jan 30, 2010 | 2006 Ford F 350 Super Duty
My FI indicator light stay on on my 2001 honda cbr, what does that mean
It means a fuel system problem. You have to count the blinks and the number will correspond with the code number. You will have to take it to a Honda shop or other cycle shop if you can't count the blinks, or you don't have the code book information.
Jun 08, 2009 | 2001 Honda CBR 929 RR Fireblade
Cameras Logo
47 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
