Question about LG Microwave Ovens
Goldstar MV-1526W Microwave Oven caught fire over the control panel. The fire was on the connection to the LG Magnetron 2M214 can it be fixed?
Goldstar Microwave Model MV1526W - LG Magnetron 2M214 - 39F & PO 301-028277
    Top Expert:
  • LG Master
  • 45,468 Answers
Take it to a repair shop for a proper diagnosis but generally anything other than a fuse , it will be cheaper to get a new unit
I need a magnetron for a Brother MF3200 microwave oven
How did you get on with your search for a new Magnetron ??
I have one of these great little cookers, but the buttons on the control panel are "sticking" or only intermittently operating - have to press pause many times to get the machine to shut down. I might need a new control panel or at best the one fitted needs a good internal clean - have you stripped your mmachine down ??
Jun 21, 2012 | Microwave Ovens
Our microwave MV-1310 has stopped heating food? How much would it cost to fix it?
The cost depends only after identifying the fault and if this is only a fuse you have just got to replace. So remove power and top cover, check for the fuse near the main power line. If this is OK , check the controller unit and if the microwave works without heating, it can be a faulty waveguide- or a magnetron.
The wave guide is not expensive but the magnetron is the critical and costly part and where you need an estimation.
Oct 08, 2011 | Goldstar MV-1310W/B Microwave Oven
My microwave appears to be running, but nothing is heating up
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Oct 14, 2009 | Goldstar MV-1502 Microwave Oven
GOLDSTAR MV-1310/STOPPED HEATING
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Feb 02, 2009 | Goldstar MV-1310W/B Microwave Oven
Microwave has no power
I'd say the thermostat and/or fuse are blown. I just hope the magnetron survived.
I don't have that exact model's service manual but ones before and after only used one thermostat, similar to the drawing below.
They also have a fuse, usually located in an inline fuse holder connected to the power cord inside.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
Aug 21, 2008 | Goldstar MV-1515 Microwave Oven
Heat up
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
In this case, the magnetron is the most likely suspect, but other suspects would be :
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Goldstar MV-1715 1000 Watts Microwave Oven
Goldstar NV1502 No Heat
You should still have about a 5-year warranty on the magnetron, if that's the trouble.
If everything else works, it's almost certainly a high voltage component, most likely the magnetron or diode, but also possibly the transformer.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
I would contact LG / Goldstar first. For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
May 05, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar MV-1610 Microwave
We also have a service manual for the MV-1615, which is similar. I have uploaded it to our site here.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 26, 2008 | Goldstar MV-1526 Microwave Oven
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
