Question about Dell Latitude D600 Notebook
Dell D600 turns onfor 4 seconds
Hi I have got this dell D600,when i turn it on ,it starts then makes a low DIK DIK DK noise and turns itself off,
i have tried running it from the battery alone,and have taken all the other components like the optical drive and the hard drive out, but still no change ,,
please help
  • ziyan Nov 22, 2007
    i have actually fixed this problem by changing to a another power adapter, thanks for the help though
  • 42 Answers
Posible a fan fail.
Posted on Nov 21, 2007
  • 196 Answers
That noise is typical of a bad hard drive. Are you sying the noise continues even with the HD removed?
Why does my laptop latitude d600 charger goes off completely when connected to the laptop
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 14, 2011 | Dell Latitude D600 Notebook
My dell D600 laptop turns off by itself. when i turn on the caps lock light blinks four times and the laptop turns off.....please help
Just reseat (remove & put back) the RAM (memory).
you can find the procedure for removing the memory in the support.dell.com. Follow the steps given below.
1.GO TO support.dell.com,
2. Click on "Manuals"
3. Select your system, or put in your service tag.
4. You can either view or download the manual for your system.
Hope this info. was useful....
Oct 07, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 wont turn on
test power supply- test ram- have cpu tested- test connection from front button to motherboard
Aug 06, 2009 | Dell Latitude D600 Notebook
Dell D600 Wont turn on sometimes.
Reseat the harddrive (take out the screw and slide it in and out)
You can run diagnostics, during startup (just after Dell logo) press F12,then select Boot to Utility partition, or Diagnostic partition.
It may reveal you issue
Hope this helps
Feb 04, 2009 | Dell Latitude D600 Notebook
Power button
try one step if that doesnt work contact the dell tech on 18006249896 it could be a major hardware failure
remove the battery and also the power cable and hold down the power button for 10 sec and than connect the battery and the power cable and start the pc that should work
Jan 12, 2009 | Dell Latitude D600 Notebook
Dell D600 Notebook
So.. no sloution for this problem. Mine also did the same thing.
Jun 23, 2008 | Dell Latitude D600 Notebook
Dell inspiron windows xp starts then turns off within seconds
log on to www.support.dell.com
there on the left hand side thate is an option which says technical support
click on technical support
under that you will see an option which says manuals
click on manuals
either choose your system model or enter the service tag of your system
you have to click on service manuals
you can get each and every info regarding opening your computer
Jun 09, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600
Check that the cpu fan is working. In easynote usually you uncrew a panel at the back of the laptop. If it is not that may be a common system problem, in that case reinstall your system.
Mar 13, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Wont Start
I would suggest removing the battery, then try powering the unit on. Many laptops will not start if the battery voltage is too low. Many batteries will read a lower voltage than minimal when they are at or near the end of their service life.
Jan 08, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
136 people viewed this question
Alun Cox
