Question about JVC Televison & Video
How do I reset my JVC 70 inch projection screen TV
SOURCE: jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Posted on May 04, 2007
  • 1694 Answers
SOURCE: 55 inch projection tv
Here is your screen info = protector...PS5501....$155.00
Lenticular = 23430819....NLA Fresnel..23430635...$135.00
Posted on Dec 17, 2007
SOURCE: cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Posted on May 11, 2008
SOURCE: I have a 56" JVC rear projections HD ILA tv.
Turn tv off and unplug it. Take the access door off either side of the tv. Use a dust cleaning tool like a swiffer with an extension (or make one). Clean off lens (most likely the problem). I have the same thing that happens to my JVC 61". You can use a vacuum with extension if your VERY careful.
Posted on Aug 31, 2009
SD Tech
  • 14553 Answers
SOURCE: JVC 48 inch rear projection tv with 2 spot in
yes, I know what is wrong and there is a simple way for you to confirm this.
Have you ever seen a TV with just a white line across the screen from left to right? On a regular TV if this happens and you leave it on long enough it will burn the mark into the screen.
I suspect what you have is two of the picture tubes in this projection TV have a burn--it is caused because the set lost either horizontal or vertical sweep--picture either closed from left/right or top to bottom for a moment and then came back on instantly---burns a mark in one or more of the 3 tubes screens.
Way to confirm is simple--with the back cover removed cover each lens one at a time with the set turned on--be very careful when you do this not to touch anything else---
if you cover a lens and one of the marks goes away that tube is burnt----my guess is you are going to find at least 2 of the 3 tubes are burnt on the screen---
Problem here is the tube or tubes need to be replaced to correct this AND whatever caused this HAS TO BE FOUND ALSO OR IT WILL DO THE SAME THING TO THE NEW TUBES--
CONSIDERING the cost of two or more replacement tubes you are most likely better to buy a new TV---I have seen about 100 sets with just exactly what your are describing---It does not happen a lot--but once it happens the damage is permanent.
I know I am not giving you good news but I am sure from your description this is what has happened.
Sorry to give you bad news---see for yourself if you cover each lens one at a time--if you do this and the marks are gone you know exactly what has happened.
IF YOU HAVE ANY QUESTIONS OR NEED MORE INFORMATION--let me know here--I am here to help but cannot always give good news.
Posted on Oct 07, 2009
Green and Red (thin lines) across entire screen [JVC 70 G886 HD TV]. Screen went to all green (wide and thin) within 1/2 hour and picture hasn't come back. "Input selection" box is visible and clear...
Try a "hard reset" first by unplugging the set for 30 seconds. and if no help, you may have a problem with the SMPS power supply, it might have a bad capacitor or two by now. Worth repair if engine is good compared to a flat panel.
Apr 22, 2014 | JVC HD-70G886 70" Rear Projection HDTV
I had an amplifier hooked up and it went bad. discconnected it and now we have no sound. Went through the manual and changed the settings but still no sound, any suggestions?
recheck the cable connection, and use the multimeter for measure the continuity, and replace if necessary, clean for oxide, corrosion use the WD-40 and try again.
If the problem persis go to the repair shop TV.
Nov 03, 2013 | JVC HD70FN97 70-Inch 1080p HDILA Rear...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
I have a 56 inch JVC HD TV model# HD-56G647. yesterday when I turned the set on there was a black shadow in the lower hand corner. today it's bigger. i called jvc and they told me to make sure the...
Red light lamp indicator is blicking on my 56 inch mode;# 56G647 tv and the Tv screen is black with no vision of tv and no sound. What sould I do
Oct 17, 2008 | JVC Televison & Video
Jvc projection tv
try this site
Jul 16, 2008 | JVC AV-56WP74 56" Rear Projection...
Cleaning JVC rear projection screen (behind cover)
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
