Question about Cameras
Tablet cammera error cant connect to the camera
  • Cameras Master
  • 5,412 Answers
Please repost this query under Computers - tablets.
Lost my plug in for the kodak easyshare c330 where can I get one to plug into camera and computer
If you want to download the pictures and movies from the cammera you can unload the memory card from the cammera and insert it in a card reader and then to the usb and without a cord you can do this easily, but you will get the cord in a cammera shop. available in your locality.
Sep 09, 2010 | Cameras
A friend bought a nec cammera on our holiday and
Need more info...where were they downloaded to?...a folder, my pictures, or a software program?
Feb 11, 2010 | Cameras
Camera has different problems
Ok, these cammeras seem to have a lot of problems. My suggestion is to seriously look on ebay or ecost.com and buy a new cammera to fit your cammera housing but if you are dead set on repairing yours then i would say open up the cammera body and there is a card on the front you need to replace. I would try the large card on the front of the cammera next to the lense first by the vauge description you gave. this seems to control all the processing. you may want to try a couple of simple things first like using a different memory card or replacing the batter inside the cammera. I don't know how a bad battery would effect the cammera operation but it is possible it could cause problems. If this doesn't help then take the cammera appart. REMOVE THE BATTERIES! REMOVE THE MEMORY CARD! THERE IS A CAPACITOR INSIDE THAT WILL SHOCK YOU, DON'T TOUCH THE CIRUIT CARD ON THE FRONT WITH OUT DISCHARGING THIS CAPACITOR!!!!!!!!!!
remove the screw around the outside except for the battery compartment and the retainer screws holding in the screw tripod mount. They can stay in. next lift the bottom of the back cover up and hinge it slightly forward. not too far. then carefully pull the top of the back cover away being careful not to shear off the top plastic snap in pieces or hinge it forward and break them! do not pull it off quickly because there is a ribbon cable holding in the back. Back off the ribbon cable retainer clip and remove the ribbon cable from the socket. This should remove the backing. Next remove the newly exposed screws and remove the ribbon cabble for the shutter switch the same way. then pull off the front cover carefully. let it hang by the micophone wires and what not and you will see the board on the front next to the lense with the capacitor that shocked you... Didn't I tell you to watch out for that! now tell your wife you were shocked incase your heart stops... next discharge the capacitor the rest of the way with a piece of wire. it should be the solder joints with the big re and black wires next to the lense. Then un screw the board and unplug the wires for it. remove the board and look for serial numbers. Look the numbers up on the internet or on ebay and try to find someone who is selling it for cheap. This is nearly impossible to repair and must be replaced. if you cant find a replacement, call olympus and ask for a replacement board. they will then tell you they dont sell them so lie and tell them you are a repair shop or alternately ask to speak to their repair department or a certified repair shop. call them and ask if they have the part and usually they are more helpful. Ask how much it costs and then realize that it is almost the same ammount as buying a new cammera. get mad and look some more on ebay for the part. once you find it... order it, install it, test it, and email me back and let me know if it worked at Lucient_lost@msn.com Also be carefull not to shear off the switch on the botom for the memory card door. It is very fragile. if you do there is a fix for it already on this web sight. I wrote that one too. If you have any more trouble with it email me. if something is unclear, email me and I'll call you.
Jun 21, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Can't transfer pictures to pc.
you can download the drivers of your cammera on the internet and install them...
try in google or in the website of the cammera´s brand.. there you could find the drivers..
if you still have problems i could help you finding them..
cheers
Mar 24, 2008 | Samsung L73 Digital Camera
Canon digital camera power shot A510
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 08, 2008 | Canon PowerShot A510 Digital Camera
Camera
okk try this code *2767*2878# if it dont work try this code *2767*3855#
Dec 01, 2007 | Samsung SCH-u740 Cellular Phone
Lost cd before loading onto computer.cant find one anywhere
what operation system are you on? in xp the os will pickup the camera and download the pics for you, but if you have movies it won't.
plug the cammera in and let the usb cable connect to camera. if the "what program to use to donwload..." comes up, either:
1. select something other than fuji software w/always selected or
2. select do nothing right now.
if you chose do nothing right now, go to windows explorer and look for the cammera as a hard disk drive (removable drive ect) under my computer. open it up and there are all your pictures/movies. select alla nd copy to your favaorite place on the hard drive.
if you choice was with windows soft ware I'm pretty sure the movies WERE NOT copied. check the folder the pics are in and you may have to go to the "my computer" folder to find them
FOR NOW. call me back and I will look for the disk/software
hope that helps:)
Oct 17, 2007 | Fuji FinePix A120 Digital Camera
Camera does not stay on
read manual on how to reset the camera...may be a small pinhole...
Jun 01, 2007 | HP Photosmart M527 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
