Question about Ryobi Tools & Hardware - Others
I want to do dovetails and just got a ryobi plunge router. How do you put on template guide for the router to use for the jig.
rowdy45176
  • 2176 Answers
SOURCE: Ryobi RE600 plunge router binds on the posts
Are you cleaning the area that contains the springs also and if so I would use something like a dry lubricant so that it won't attract more dust and dirt but we both know that eventually it will. Coat the posts with this and allow to dry and then push up and down on the motor to lube the bushings and you might have to do it again. You can also try a small amount of 3 in 1 oil but use sparingly.
Posted on Feb 16, 2009
  • 86 Answers
SOURCE: Dovetail leave a 'light gap'
This may not be related to your jig. It may be movement in the vertical axis resulting from:
  1. The router bearings being worn allowing the bit to move up and down.
  2. The router bearings worn allowing the spindle to deflect side to side which changes the bit height slightly (cuts on the edges, making the cut a hair deeper).
  3. The router collet or router spindle worn, allowing the bit to move during cuts.
  4. The jig guide plate deflecting or no longer flat.
  5. Excess vibration in the router causing the wood to move in the jig.
To check the bearings; try routing the cut with a straight bit first to clear the wood for the dovetail bit. Then cut with the dovetail bit (a new one preferably) using very light feed pressure. Is the joint tighter? If so then the bearings are worn. Have the router serviced or replace it.
Check the end-play by pulling on the router shaft, does it wiggle slightly in and out? If so this is your problem. Have the router serviced or replace it.
Be sure the wood is flat and the faces planed parallel, if they aren't the dovetail line will be straight but when you assemble there will be slight end gaps in sections of the dovetail.
Posted on Feb 28, 2009
SOURCE: I am looking for an owners manual for a sears 12
http://www.managemyhome.com/
Sears does a horrible job of getting this info out, but this is the website that has all their manuals for Craftsman power tools.
Posted on Jun 28, 2009
SOURCE: I need an owners manual for a Craftsman dovetail template
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0804094.pdf
Posted on Aug 28, 2009
  • 384 Answers
SOURCE: reading the book is not clear on how to alline the
Give the instruction to a nine year old and let them explain it to you.
Posted on Sep 08, 2009
Are the 7 degree dovetail bits, that come with the jig, the only size that can be used or can a 9 degree bit be used?
Hi, W/D at your service.
Apparently, there are several types of bits compatible with your model.
Here's a link that gives you a better idea:
http://www.toolup.com/porter-cable_4216_12-deluxe-dovetail-jig-combination-kit.aspx
Best regards, --W/D--
Feb 23, 2011 | Porter Cable Porter-Cable 4216 12" Deluxe...
Where can I purchase an owner's manual for a Craftsman dovetail jig Model # 315-25710 A2044? Virgil
You might check this out, I found it in another forum. It looks like Ryobi made this dovetail jig for Sears.
1-800-525-2579 is their customer service line. I would ask for Ryobi Tech Services.
Nov 22, 2010 | Craftsman Saws
What is the router bit depth for a shop fox dovetail jig
Usually with router dovetail jigs one has to find the depth by trial and error as the fitting is very critical and any discrepancy doubles as the cut is on both sides of the joint.
I think you may have to play this game.
You will need offcuts of the same size as the finished work that are long enough to go into the clamps of the device and then just fit the joint by trial and error. It is the way we do it in the trade. Sharpening of the cutter and different thicknesses of wood all affect the fit of the joint.
If my memory serves me raising the cutter up toward the machine makes the joint looser and lowering it makes it tighter. If I was in my workshop with the machine in my hand I would remember for sure
May 31, 2010 | Tools & Hardware - Others
I need a 7/16 (12mm) template guide for a bosch POF 1200 AE router. Where do I get one? Regards Paul.
various tool shops. try www.axminster.co.uk or www.rutlands.co.uk both are good tool suppliers with a good range of parts
Jan 30, 2010 | Bosch Plunge Router
How do i get a nice finish on the end of my worktop using a worktop jig ?
i have this router and it is the nicest one i have ever used. setting up a jig take time and if you are only making a straight cut then put a straight edge along your top and clamp it down. you only need the distance from the roller on your bit to the back endge of the router fence. set the straight edge that distance from the front of your top. I suggest tryinng it on a scrap piece of wood to make sure the distance is exact and the profile being cut doesnt need adjusted
Dec 19, 2009 | Bosch Plunge Router
Omnijib 24" - Dovetails too tight on half blind dovetails
I haven't used one for years, but I seem to remember we used to have to dial in the thickness of the planed material just right to get the joints to fit correctly. Doesn't make a lot of sense, particularly if you're using composite boards. And make sure everything is clamped in the jig nice and square, and flush where it's supposed to be.
Also make sure you are running the guide collar right up against the fingers when you cut, maybe take a second pass through. Make sure the bit you're using hasn't been resharpened....Take pains to be sure the bit is centered in the collar.
If you've done all that, I'm afraid you just have to play with it until you get it to work...use some test pieces and you'll see that the depth setting does affect the fit, but they're not as versatile as an infinitely adjustable jig like a leigh. I'm afraid I'd have to put my hands on it to remember and see what wasn't working...
I hope that may help in some way or another...
Here's a link or two that might help as well:
  • http://www.newwoodworker.com/dovetails.html
  • http://woodworking.about.com/od/dovetailjigs/gr/PorterCable4212.htm
  • http://www.woodmagazine.com/woodworking-tips/techniques/joinery/9-steps-to-great-looking-half-blind-dovetails/
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 10, 2009 | Tools & Hardware - Others
Feb 23, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Tools & Hardware - Others Logo
57 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
