Question about Maytag Neptune MDE4000 Electric Dryer
Loud noise on the left side that continues throughout the cycle.
It is getting louder and vibrating. When you open the door it looks as if the drum is slipping as it comes to a stop, like it's not fully turning. Lots of heat but not much air. I thought the belt might be strethched out.
  • 55 Answers
Hello.
You will need to replace the drum rollers on your unit. If you take the model number to a local appliance store and tell them you need the drum rollers, they will be able to get you instructions on how to replace them.
Posted on Jul 23, 2009
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
When in spin cycle machine made a loud noise then the spin cycle continued but very loudly. the machine would continue to wash clothes as normal and then get loud during the spin cycle again. at this point...
Hi if you can do it yourself, put the machine about 2ft away from the wall with the door faceing the wall,then lean it against the wall,this way you can look under the bottom off the machine,check to see if the drum moves from side to side,some times the shock absorbers come loose 1 at each side,all the best.
Jun 15, 2017 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer makes loud banging noise on spin cycle and walks across the floor. The drum rotates fine on other cycles and belt seems to be intact
Have you removed the bolts at the back of the machine. they are there to help stop it getting damaged in transit but if left in when in use it vibrates violently and moves a lot read manual and look at back to see if bolts are left in and remove them if so. hope this helps.
Dec 28, 2010 | Samsung WF337AA Front Load Washer
Frigidaire dryer FERB5700DS0 loud vibrating noise when heating up and gets louder during use
drum glides, drum rollers or idler assemblage which is next to motor. This website will explain how to open dryer and the glide/rollers, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Nov 27, 2010 | Frigidaire Dryers
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Very loud noise BUt washes fine
could be wheel on back of drum check its not loose , only way to get to filter is to remove the pump from filter assembly lay it on the soap draw side to get to it easier
Apr 04, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Maytag Neptune MDE4000 Electric Dryer Logo
126 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
