Question about GE Refrigerators
GE replaced motherboard and control panel display board, light switch too. Now get o and OK on display have done reset lots of times. To get it to work I slam the shelves inside the freezer and it
Starts till freezer is opened again.
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: BenQ FP51g LCD monitor
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
Posted on Oct 25, 2008
Just_Bobz
  • 448 Answers
SOURCE: GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Posted on Jan 10, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE refrigerators GSS23WSTASS: The control panel on
GSS service manual
Posted on May 13, 2010
  • 25 Answers
SOURCE: GE side by side freezer shelves falling down
This appears to be a known problem with at least a couple of GE models (It has been happening in our freezer too). There is a GE Service bulletin at https://customernet.geappliances.com/OTIS/fs/home_images/REF01-10.pdf that seems to describe the fix as them sending out new shelves (and maybe someone to install them?)
Posted on Jul 12, 2010
Pc Er Error code
Jim, Pc Er is a Communication circuit failure on main board or
Communication circuit failure on control panel board
Could be a loose or corroded connection, a bad mother board or a bad display board. Before doing anything, unplug the refrigerator for 5 min and plug it back in. This may reset the motherboard. If not, check the comm cable at the display and the motherboard. if ok, then you will need to replace either the motherboard or the display board. There is no way of determining which one to replace.
Apr 10, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
GE JNM 1851 microwave display panel light is out
The GE Answer Center is telling it like it is. Bet it's touted as a customer-friendly "improvement".
Sep 05, 2017 | GE Microwave Ovens
My ge washer model wjsr4160g1ww will not spin or aggitate
A lot of times when that type GE Hydrowave washer does not spin/agitate it can simply be resolved by resetting the motor control board. This tip i wrote explains how to reset the motor inverter board and see if that resolves the problem with the washer. http://www1.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
If ya try restting it and it does not work watch at the little green light on that motor board and see how many times in a row it blinks and reply with that number of times it flashes and i will tell ya what error code is being displayed
GENE
Oct 23, 2011 | Washing Machines
GE Washer Model #WLSR3000GIWW does not agitate or wash. Timer completes cycle. You could hand turn tumbler. Lid switch is ok. Is this a switch or relay problem.
A lot of times when that type of washer doesnt work the motor control board needs to be reset.
To reset the board;
follow the step by step instuctions in the video
Aug 30, 2011 | Washing Machines
GE PSS26MGTABB Side by Side Refrigerator not working at all
the mother boards are not always obvious...but thats yer guy
Mar 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE JS998SOH1SS No Display on panel. Touch panel doesn't work. No oven light.
I have exactly the same problem with the same model (J S998 SOH1SS). Top is working and display went blank overnight. It will be costly and a few times I must stay home.
GE has sales and repair in US - but work is done offshore.
Never will buy from GE again – let them find buyers oversee.
Jul 05, 2008 | GE Profile JS998 Kitchen Range
Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Feb 02, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
