Question about Lemax Carnival Village Collection Junior Flight School 74703
Lemax ferris wheel. clicking sound in hub. once per revolution. opened based but can not figure out how to open hub without damaging unit
Hi i dont know if you ever resolved this but can maybe help let me know ill see if you reply :))
Posted on Jul 14, 2018
How abs speed sensors works in nissan sentra?
Sensor in the wheel hub measure how many revolution per minute and that is compared to the other wheels. Then a complex algorithm determines based on the wheel sensor as well as whether the brake pedal is depressed and other sensor input if there is any need for the abs system to modulate the brake for a specific wheel to eliminate wheel slippage or spin.
Jul 21, 2016 | Nissan Sentra Cars & Trucks
Only started when fuel is added to the throttle body?
The good news is that it isn't compression or spark and the engine can run.
Borrow scanner and read OBD data. It may provide you the answer.without having to diagnose.
  • The first check is to see if the fuel pump is running?
    • You can usually hear it for 1 to 2 seconds when you first turn the key to the run position. It will have a little whine sound. No pump running on fuel pressure no start! You may need to have one person turn the key and the other(the one with the best hearing) lay near the drivers side rear wheel and listen.
  • The next check is to listen for the click of the fuel injectors.
    • Get the guy again with the best hearing and with the hood open take a rod between the top of a fuel injector and your ear and listen as the engine cranks. they will click once every other revolution. About once per second. No click no fuel no start.
  • Pump whine OK, injector click OK, need to check fuel pressure!!
    • Need to have a fuel pressure gauge connected to fuel rail and observe pressure. If the pressure regulator is bad or if the fuel filter is plugged or ice in fuel line or what ever no fuel pressure , yea no fuel no start.
Jan 11, 2016 | Cars & Trucks
KitchenAid standmixer (professional 5 pro) makes clunking noise when attachment is in hub.Grinderworm (from food grinder) slips rotation regularly as well.Without attachment everything sounds normal.
Open the gearbox up and look inside, the damage will be obvious once you clean the grease away. You aren't going to fix it from the outside so opening it is going to be part of the solution.
Dec 14, 2015 | KitchenAid Food Mixers
I have a clicking noise in the right rear of my 2005 Mercury Grand Marquis. It sounds like it clicks in time with the tire rotation
There are brakes shoes inside your rotor , they are for the emergency brake, lightly apply the e brake see if it changes the noise it may go away after you take. It off, rust builds up in ther
May 04, 2015 | 2005 Mercury Grand Marquis
2011 camry noise left front wheel when turning
Is it a "clicking" sound?
3 clicks per tire revolution?
It may be a worn out CV joint but on a 2011?
Is it a "grumble/rumble" sound?
Would you call it a "squeak"?
Can you describe the noise,please?
Mar 07, 2013 | Toyota Camry Cars & Trucks
Mouth does not move
Motor operating mouth assembly is bad. The process to remove it is tedious and the motor is specific to the design. This was a common problem with all of the motors in this series. Especially the one operating the mouth. The input pulsing necessary for the mouth to move, was to abusive to the motor, and subsequently shortened its life.
Dec 18, 2011 | Gemmy Bing Crosby Big Head Doll
Trying to take apart the lemax spooky town witches brew haus. I've taken out the screws but it still won't separate from the base. Any ideas?
I tried, it looks like its still connected under the two witches that move. Mine got stuck and the witch don't move any more, but i see 2 may be 3 screws under the pot with the skeleton.
Oct 18, 2009 | Lemax Toys
Under a heavy load, the mixer began clunking once per revolution
Disassembly and inspection is the only way to verify what it is. It sounds like you are correct. I have bought parts very reasonably on line and repaired our K/A mixer. The better sites ( I think I used appliancerepair.com) have exploded diagrams. If you are tearing into yours, these are invaluable, and when you get to the broken part, you'll have a name for it.
Best regards, --W/D--
Aug 06, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Looking for instruction/manual for knex ferris wheel
Did you ever find your instructions for the knex ferris wheel? I have them.
May 10, 2009 | Toys
Noise once every revolution
You either have a bad bearing in one of your wheels or in your bottom bracket ( where the crank is connected ) It could also be a pit in the bottom bracket where the bearings ride. If this thump occurs about the same spot on your cranking revolutions I would say it is a pit in that bottom bracket. If it were the bearings themselves that were worn the thump would be more random. The first thing to do would be to remove the chain from the crank. Then crank the pedals using your hands and see if you can feel that thump or vibration with your hands. If you feel it there then replace the bottom bracket or get new bearings. If this does not solve your problem then check the wheel bearings. Just take the wheels off and spin them while holding onto the hubs with your hands. If the wheel bearings are bad you should feel a roughness or vibration while spinning them. Since you described this as a thump I would say problem is not your wheels. They would make more of a clicking sound. Good Luck
Jan 27, 2009 | Cycling
Lemax Carnival Village Collection Junior Flight School 74703 Logo
194 people viewed this question
Top Lemax Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Lemax Toy Expert? Answer questions, earn points and help others
