Question about Lexmark X5650 All-in-One InkJet Printer
I have bought a new Lexmark x5650 Printer. The setup all went fine but everytime i boot my PC running Windows XP the screen just hangs. When you take the USB cable out of the Printer the PC carries on booting.When you plug the USB back into the printer everything works OK. The Pc seems not to recognise the printer on boot.
  • 365 Answers
Issue: Computer will not boot with the device connected via USB to the PC
Solution: Disable USB Emulation (legacy support) in the computer BIOS
Turning off USB Emulation (legacy support) in the computer's BIOS
The following steps are for Dell computers. If this issue is occurring on another brand computer, the process of entering the computer's BIOS may be different. Additionally, the steps to make changes may differ as well. Refer to the computer's documentation to verify the appropriate steps to disable USB Emulation.
For Dell computers, perform the following steps:
While rebooting the computer, press the <F2> key to enter the System Setup (BIOS).
Press the Down Arrow <?!> key repeatedly until 'Integrated Devices' is highlighted.
Press <Enter> and another window appears.
Press the Down Arrow <?!> key repeatedly until 'USB Emulation' is highlighted.
Press the Plus <+> key to change the value to 'OFF'.
Press the <Esc> key to exit this window.
Press the <Esc> key again to exit the System Setup (BIOS).
When the message "Do You Want to Save Changes And Exit" appears, press the <Enter> key indicating Yes to save changes. The system will reboot.
Posted on Jul 21, 2009
Lexmark x5650 all in one won't download application list
Try to download and install the Lexmark X5650 printer driver for Windows 7 from the Lexmark website. First, disconnect your printer from your computer. Then, check if your computer system is running on 32-bit or 64-bit. On your computer, go to Start > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below for the corresponding driver for your operating system:- Lexmark X5650 driver for Windows 7 32-bit- Lexmark X5650 driver for Windows 7 64-bit
Simply follow the instructions on your computer screen to complete the installation. Then try to scan again to verify that the problem is fixed.
Nov 16, 2011 | Lexmark X7350 All-In-One InkJet Printer
I use win 7 and have 5650 all in one i cant print maps or doc off the net why ty
It could be a driver issue. Try to uninstall any existing Lexmark X5650 driver from your computer first. Go to Start menu > Programs > Lexmark X5600 Series Printer > Tools > Uninstall. Reboot pc when prompted.
When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit system type. Go to Start menu > right-click on Computer > Properties. Take note of the System Type. Then download the driver using the links below:
- Lexmark X5650 driver for Windows 7 32-bit - Lexmark X5650 driver for Windows 7 64-bit
Jun 19, 2011 | Lexmark X5650 All-in-One InkJet Printer
My computer won't boot up while my Lexmark X5650 is connected and turned on. Dell computer running XP pro. When I turn the printer off, it will boot.
Try moving the USB cable to another usb port. Ports can go bad; or if the printer interface is bad; it will cause this type of problem. If you want, you can try another cable too. In the end, you may end up having to replace the printer. But, certainly try another port first.
Oct 19, 2010 | Lexmark X5650 All-in-One InkJet Printer
I install the software.printer is works,but when i want to use scan,there is on the screen ocr software mising ,install the software.on the printer scan is failed.how can i scan?thanks
In this case please insert the disk to the computer goto My Computer in XP and Computer for Vista...... There u will see a icon which says DVD RW lexmark 5600 u need to right click on it and click on explore and then click on Abby and run the setup.exe file and then try to scan it will work fine................
Good Luck
May 17, 2009 | Lexmark X5650 All-in-One InkJet Printer
Didn´read the instructions
Unplug he USB and Power on your printer.
go into cotrol panel - then open the printers/fax folder.
Right click on your printer in question and select delete.
Install software and drivers from CD or download from lexmark website.
Shut down PC
plug in USB and Power to printer.
start PC and let it install using the drivers you just Downloaded.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 07, 2009 | Lexmark X5650 All-in-One InkJet Printer
I lost the Lexmark X5650 Printer, Scanner, Copier and Fax CD, What can I do?
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Mar 05, 2009 | Lexmark X7350 All-In-One Printer
Compatibility between new computer and potential new printer
the x5650 is compatible with XP, Vista and Vista 64
Nov 26, 2008 | Office Equipment & Supplies
Installation of a downloaded driver for Lexmark X1290 All-In_One
You need to download the Vista compatible setup here from Lexmark,
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:567:0:0&searchLang=en&os_group=Windows%20Vista&target=
Run the setup after it finishes downloading but ONLY connect the printer to the computer when the setup instructs you to do so.
Apr 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X5650 All-in-One InkJet Printer Logo
403 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
