Question about Bose Audio Players & Recorders
Have a Bose media center model AV3-2-1 that won't eject DVDs. Any ideas on how to get the current one out?
  • 3 Answers
Your disc is stuck in the DVD ROM drive.It is recommended that you contact a qualified Bose service Technician who will be able to get your disk out without damaging other parts of the Media Center.
Posted on Feb 26, 2017
quang123
  • 107 Answers
SOURCE: TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Posted on Dec 15, 2008
SOURCE: Disc won't eject
the disc on the drive cannot eject.how can i fix it?
Posted on Apr 29, 2009
SOURCE: need remote for bose av 18 media center
I have a bose system and my remote control model RC18T1-27 does not respond at all> I thought maybe it is the batteries and thaty didn"t sole the problem. It has not been droped or anything it just stoped working all of the sudden
Posted on Jul 11, 2009
  • 4 Answers
SOURCE: We have a dvd stuck
See original post below for help.
http://www.fixya.com/support/t329722-bose_321_dvd_stuck_open
Cheers
Posted on Oct 31, 2009
SOURCE: We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Posted on Nov 06, 2012
My Bose lifestyle DVDs player no color only black and white!
What series is your Bose Lifestyle System?First,check if the composite video output from your Bose Media Center is connected to the composite video input of your television.It will only show black and white if it is connected to the component video input of your television.
May 25, 2017 | Bose Audio Players & Recorders
There is a cd stuck in the system how do i get it out
This solution is from the troubleshooting section of the manual:
• Follow these steps:
1. Turn off the unit.
2. Unplug the Acoustimass module power cord from the outlet for 60 seconds, then reconnect it. This
allows the unit to reset itself.
3. Before powering on, press and hold Eject on the media center.
Hope this info may help you!
Mar 10, 2011 | Bose 3·2·1 II System
Media Center disc tray will not open. When the "Ejecting" light displays, there is a whirring sound for a little bit but the tray does not come out. There is not a disc inside. I have disconnected the...
This is a common problem with optical drives. There is a small band/pulley inside that connects the ejection motor to the gear action, This reduces stress on the gears and it helps with smoother motion while running. The issue comes in where the band/pulley becomes worn out and loosens a bit and this causes a reduction in friction against the spindle the band/pulley is on. You may need to get a new band/pulley for your optical drives ejection system in your media center. The whirring sound you happen to hear it the ejection motor spinning but its not catching on the band/pulley.
Mar 12, 2010 | Bose Audio Players & Recorders
2003 silverado CD player
HI. you will need to replace the loading dock motor. once this replacement is done, you will have no problem loading and unloading your media. This repair will need to be initiated by Bose unfortunately. you will need to send it to Bose.
Jun 05, 2009 | Bose 32023 CD Player
Disc tray does not always open
well i understand why the remote won't eject the disk because there is no eject function button on the remote. The top pannel function button's are the only way to eject a disc on this system. on these units I have seen the button's go bad and need replacement. More likely the dvd section of the unit is starting to go bad. Bose has a reasonable factory repair rate. The drive swap is simple but requires some technical skill. Obtaining the drive is difficult as bose does not sell just the drive. I have listed myself and seen some listed on ebay for sale. I hope this helps. Dan
May 31, 2009 | Bose 3 2 1 GS Series II DVD Home...
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
Mar 03, 2009 | Bose Lifestyle 18 System
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Disc won't eject
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Jan 19, 2008 | Teac (DW-224E) DVD Drive
Media centre control panel not working
You may be having the same problem I have. There is a ribbon cable that connects the front panel to the main control board. Mine has pulled loose where it connects to the printed circuit board that the buttons "connect" to. I would not suggest taking it apart. I'm in the process of trying to find someone who can repair mine.
Aug 11, 2007 | Bose 3 2 1 GSX System
63 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
