My Linear Series RV5090 AM\FM Stereo Multi-Media Receiver stopped working. Had worked before on previous trip on Travel trailer. I checked fuse, fuse good.Will not turn on. Connected to TV\TV works.
emissionwiz
  • 79865 Answers
SOURCE: 2004 F250 No brakelights/turn lights on trailer
You will need to get a 12 volt test light and check the trailer connector for a voltage signal to the trailer, it may also have seperate fuses under the hood for the trailer lights if the system is factory installed, federal law requires the 2 systems be isolated, if there are blown fuses find the short in the trailer before replacing fuse(s), with no exceptions the short is always in the trailer. Hint, check the fuses 1st.
Posted on Jul 28, 2008
davidkay61
  • 23 Answers
SOURCE: 2005 Chevy Tahoe Trailer Running Lights Out
Depending on what type of trailer you have, a blown lightbulb on one marker could kill them all (like the old Christmas light strings). Look at those, and make sure your ground is good.
Posted on Nov 27, 2008
SOURCE: JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Posted on Mar 26, 2009
SOURCE: Hi, Experts, Vintage Sansui 5050 receiver.
Check for 19 Kz on stero decoder that requires calibration adjustment.
Instrument you need:
Occiloscope or frequezy counter and adj driver .
Good lock.
Posted on Jul 28, 2009
  • 266 Answers
SOURCE: travel trailer roof top ac keeps tripping 20 amp
If it tripps quickly you have a direct short which means a hot wire is going to ground. This can be caused by a wire that has melted and grounded, compressor burnt out, fan motor failure, capacitor shorted, or just one of the wires running from the above to each other. First try the unit with it just running the fan.. if it does not blw the breaker then turn it to a/c . If it blows the breaker on fan you have a wire probably shorted inside the selector/fan panel open it up and look for melted or burnt ends repair the wires if found wires slowly degrade and that creates heat which causes the wire to degrade more until something melts. If it only tripps when you put it on a/c then you need to ck the panel and then go on top and take the cover off look for damaged wires ect there is an access after you take the cover off to get at more wiring. Look for a capacitor it will be a silver or grey cannister with writing on it that says 5uf or 35uf and 200 to 500volts if it is 3 wire it will be the start capacitor for the fan and the compressor if not then you should have two capacitors on 5uf and one 35uf make sure the wires look good if bad replace wires and try the unit if not you will need to purchase a volt/ohm meter at a hardware store get a cheap 10 to 15 dollar one it will come with instructions or just ask the salesman. Then you will need to unhook the wires from the capacitor. 3 wire put ohm meter on ohms and place the wires from the center connection to the outside connection one side will be for the fan and one for the compressor. When you place the black on the center and the red on the outside connection and then reverse hold them for a few seconds the meter will drop and build up to 5 or 35uf then do the other side. The center connection is the same for both sides. If you have one or two two wire capacitors you ck them the same way just put your ohm meter leads on and them switch and see if it builds up try a couple times. If they ck bad replace it. If not then your fan motor or compressor are bad. Remember th capacitors store voltage and are hot even when the power is off you can short them by using a screw driver blade do not touch with your hand. You can check he compressor by grounding one of your ohm meter leads on the compressor scratch a silver spot for goodconnection then touch each of the 3 connections on the compressor if any of them show 0 ohms or close its shorted out. Always unhook power before handling the unit or testing for ohms. hope this helps
Posted on Aug 08, 2010
Why do I have sound from the DVD but no picture?
  • Did you ever get an answer? We are having the same issue with our Acsend travel trailer and cannot figure it out.
May 24, 2014 | Jensen Awm965 Am/fm|cd|dvd|mp3/usb...
My kenwood kdc 136 works normal for ten minutes then stops and displays ;ocer
I had an issue like this took me months to fix it. I finally just put in a higher grade fuse in. I think it had a 10 and i put in a 15 worked after that but mine was not wired to the battery. I would say check your fuses and wires.
Apr 20, 2014 | Kenwood KDC-138 FM / AM Receiver
Fm stereo stopped working; no stereo beacon, no sound
Hi... try factory reset: while holding down VCR/DVR button ,press the ON/STANDBY button. "Clear" will appear on display ,and receiver will enter standby mode. :)
Jan 20, 2014 | Onkyo TX-SR876 Receiver
Instruction manual for linear series ls 3700 stereo
Stereo off
Hold down mem button.
tune up is hour
tune down is minutes
Jul 21, 2012 | Audio Players & Recorders
NAD T760 FM stereo not working
Hello
There are three fuses with your NAD surround receiver.
Reference No Part Number Description
M751*AH 5120-0200-0 Fuse 5A 125V Time Lag 5x20 MM MITI/UL/CSA
M754*AH 5120-0052-0 Fuse 1.6A 250V Time Lag 5x20 MM UL/CSA
M752*C 5120-0024-0 Fuse 3.15A 250V Time Lag 5x20 MM SEMKO/VDE
Check them first and inform me which one has blown out. I'll give you detais after that. OK.
Oct 26, 2011 | NAD T760
No sound on early 70's magnavox stereo console
i have a 70's receiver ......well actually,,, my wife's from junior high days......acted the same as yours.........i took the cover off ....checked fuses.......3 amp.......glass type with silver ends.......1 was cooked......replaced it.........just like new.
Mar 11, 2009 | Teac AG-V1050 Receiver
Multi Room Function on marantz SR-19
Hi..
Put a RCA (phono cable) splitter at the pre-out /main in.
That way you can go to both amps with the same signal
Jan 14, 2009 | Marantz SR-19 Receiver
1998 Rockwood Tent Trailer
check connections -test and check ignition ,gas valve ,thermocouple for proper placement ,dirty or damaged
May 03, 2017 | Heating & Cooling
135 people viewed this question
 Grubhead
Grubhead
