Question about Fisher and Paykel Dishwashers
Fisher and Paykel twin dishdrawer
Top dishdrawer wiring and beeping and locked in rinse cycle with no water coming through. Tried to start bottom drawer and will not start at all
  • 490 Answers
There is water in the base setting off the flood sensor, you will need to remove the bottom draw and dry the water up with a towel (make sure the power is off and unplug it from the power point) then you will need to do a bit of testing to locate the cause of the leak, if your lucky the leak was caused by incorrect dish stacking or something too big in the draw
Posted on Feb 10, 2017
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
F 2 on fisher paykel
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/590199D%20DishDrawerP7%20userguide%20USCANZAUGBIE.pdf
More then likely you will have to remove both drive impellers and give them a good clean as well as the stainless strainers . Every month or so I run a rinse cycle through them with a cup of white vinegar . this also helps with the damp smell in the warmer weather.
Good luck
May 04, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Greetings. I have a Fisher & Paykel dishdrawer - the top drawer appears to have lost power mid cycle and the lid has not retracted - no led display - no response from the buttons. The bottom drawer...
Describethe inside of unit,any wear on it anywhere, the rack the dishes go on is it plastic coated? is it wore with rust comeing though on tips here and there?
Mar 07, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Machine starts to fill then stops and beeps
try it on rinse cycle if goes ok then the hot water valve is faulty
Dec 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
Dishdrawer leaves dried detergent and crud on
1-Go to diagnostic mode.
2-Press the Start /pause button until you get the display rd for Rinse Aid Dispense setting.
3-Have warm water readu in a kettle or a pitch.
open thedispenser to pull water in.
press the Lock button to turn the dispenser on.
4-Continue to pull water onto the dispenser holder so it can flush out all the resisdue.
5-When you feel that it is enough, press the Lock button again tostop it.
6-Press the power button to get out of this mode.
7-Start a Rinse cycle to completely flush out the residue from the inner tube to the sewage.
8 The next run you won't see the white stuff anymore providing that you will use the liquid not the powder...
Jul 03, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel Dishdrawer beeping constantly
leave it unpluged to stop for now, the machine has detected a leak and is constantly running hte pumps within the drawers to try to remove any water.. problrm is the water detector is in bottom under the lower drawer and htere is no pump to remove that water ..canbge a fickle machine as far as leaks are concerned, but the easy reason is usually misloading of the drawer itself, was an item put in that was too tall , preventing the lid from coming down and sealing off drawer causing water to overflow down the side??? there should be(so logn as no previous repairmen have taken it) a tech/trubleshooing guide taped to teh back wall behind the lower drawer, which is easily removed by unlocking hte hinges on either side of the front of drawer, explained in your manual
Nov 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
May 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
96 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
