Does the pulley to the gearbox need to not slip on the shaft? Does the set screw need to be tightened if this is happening?
MODEL mwx433rew0 kELVINATOR WASHER
    President:
  • 3,074 Answers
This may help
http://forum.appliancepartspros.com/washer-repair/533129-washer-spins-fills-drains-wont-agitate.html
Singer Sewing Machine Model 9410 motor drive shaft spins inside pulley
There is a set screw somewhere on/in the pulley. Find it and try to tighten it. It MAY not be a conventional screw.
Mar 07, 2015 | Singer Sewing Machines
Pulley spins on motor drive shaft
There should be a set screw on the pulley that tightens the pulley to the drive shaft. It needs tightening.
Mar 07, 2015 | Sewing Machines
How to change belt on ilco 008b mini-mite key machine
To remove or install a belt on the Ilco 008, the shaft must be slid out of at least one bearing. If there is a guard cover over the pulley, remove it. Loosen the setscrew(s) on the cutter shaft pulley, and slide the shaft to the left. Mine is an older model, with no guard and the belt can be changed without removing the shaft completely.
After putting a new belt around the pulley, slide the shaft back into the right-hand bearing.
Be sure the pulley set screws are aligned with the flats on the shaft and that there is minimal end play and the cutter turns freely. Tighten the set screws and stretch the belt over the motor pulley.
Apr 22, 2014 | Locks & Locksmithing
Seat inca van 00 sdi 1.9 diesel.. tension polly came loose.. timing belt slipped.. I need to know how to reset it again. Where are the markings on the crank shaft and the cam shaft? Please attach any...
Timing belt set-up for a 2000 Seat Inca 1.9 SDi
1. Align the crankshaft timing marks on the flywheel / gearbox
2. Remove the valve cover
3. Lock the camshaft
4. Fit the injection pump locking pin
5. Loosen the camshaft gearwheel bolt, 180 degrees. Use a wrench to counter-hold
6. Loosen the camshaft gearwheel while holding it in place
7. Fit the timing belt in the sequence as shown in the below figure: a - b - c - d - e - f - g
8. Fit the timing belt and camshaft gearwheel together
9. Turn the tensioner clockwise to align both marks
10. Tighten the large bolt on the tensioner to a torque of 20 Nm
11. Check for correct fit
12. Lock the camshaft. Tighten the camshaft gearwheel bolts: 45 Nm. Use a wrench to counter-hold
13. Remove helping tools
14. Turn the engine two rotations by hand
15. Repeat the procedure if required
16. Fit the vacuum pump
17. Refit the crankshaft pulley. Tighten torque: 20 Nm + 20 degrees
18. Fit the timing belt cover
19. Refit the valve cover
20. Fit the ancillary drive belt
21. Refit the inlet air manifold hoses
22. Check the injection timing
Torque settings:
Camshaft gearwheel: 45 Nm
Tensioner pulley: 20 Nm
Crankshaft pulley: 20 Nm + 20 degrees
May 26, 2011 | Volkswagen Passat Cars & Trucks
The belt slips slightly. i checked the motor belt and it is okay. I also adjusted the treadmill belt per instructions with about 2"-3" when i slip my hand under it.
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Aug 13, 2010 | Landice L7 LTd Pro Sports Trainer...
My belt skips but the motor is still spinning. it was working fine but now the belt stops when ever I step on it.
Aug 13, 2010 | Icon Epic T60 Treadmill
The belt has been replaced and is slipping
Aug 05, 2010 | Nordic Track /proform Treadmill...
The belt is sliping as I walk or run
Aug 02, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Belt skips when weight goes on. It squeaks and
Jul 22, 2010 | Proform Exercise & Fitness
The belt moves towards the left when I work on it; it jerks when I ride
Jul 20, 2010 | Icon Treadmill
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
