Will a 120v pressure switch work for a 220v - Office Equipment & Supplies
4 Suggested Answers
textile
  • 10 Answers
SOURCE: how to change tension from 120V to 220V
If you are sending a sewing machine which runs on 120volts to a region that has a 240volt power supply you will need to get a
power step down converter that will fit into the socket of the 220volt supply ,and will have a socket that will hold the plug of the 120volt supply going to your machine.
the converter must reduce the 240v down to 110v .
Posted on Aug 01, 2008
  • 497 Answers
SOURCE: wire digram for craftsman air compressor
thats not going to work for one the motor is rated at 220v you would need to replace the motor with one thats rated at 120v along with a different pump. you're better off to buy a smaller compressor then do that.
Posted on Nov 06, 2009
  • 16981 Answers
SOURCE: need a diaghram on how to wire a 220v air compressor pressure switch
You should have 3 wires coming from the pigtail. White,red and black. Depending on the application you may have a green wire too, the red and black are the hot wires that supply 220. Since you did not post the type or model of switch, it is hard to tell but red goes to one side of the switch and the black wire goes to the other terminal ON THE SAME SIDE. The other side of the switch goes to the motor. The white connects to a lug on the frame, if green is present it would connect with the white.
If I am hooking up a used water pump and set for 115v setting just like old one and it squeels load but switch to 220v and it quited done to normal will that work for me okay
good question
where are you a 120v usa {backward nation}
region or a 240v region uk or europe 220v ac
you question is far to vague and not right
its set to 240v and its quiet and 120v it squeels
perhaps thats why the old one gave up ???
if you live in a 240v area and the old one failed when set to 120v
its a feking no brainer
the old pump died because it was set to use the wrong voltage
therfore if you live in a 240v area like say the uk or france europe in general 220-240 then set it too 240v and quiet
its obviously happy. and quiet...
Mar 04, 2015 | Washing Machines
Need a power transformer from 220v input to 120v output
Yes, you need a step down transformer. These are often rated in watts (the power rating is the same on both sides of a transformer) so it is easy enough to match this with the power consumption of the stereo. Apparently you will need about a 4kW transformer eg
http://www.220converters.com/store/p/45-Simran-THG4000-4000-W-Watts-Step-Down-Voltage-Converter-220v-to-110v-Transformer.html
Ugly things.
Jun 23, 2017 | Crest Audio CC5500 Amplifier
Need a power transformer from 220input to 120output
What you need is simply a power converter device that knocks the power down for your device. Look for a UK (European) to USA power convertor on somewhere like Amazon.
May 04, 2013 | Bose Lifestyle SA-3 2-Channel Amplifier
How can i change my 220V jet pump into a 120V jetpump?
Why do you want to?
You have to change the motor to a 120v model, same frame.
Service wiring has to have a hot, neutral and a ground. You should already have three wires so that is not a problem, just have to move one of the 220 hot wires to neutral. That will give you one hot, one neutral and one ground wire to make your 120V circuit.
If you only have 120V service and a 220V pump motor you can purchase a step up transformer that will take 120V in and give you 220V out. You must know the power in watts or KVA of the motor in order to purchase the correct step up transformer.
A bit more information about your situation would help.
Aug 19, 2012 | Plumbing
Wire digram for craftsman air compressor
Oct 27, 2009 | Air Tools & Compressors
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
Changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
May 05, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Nov 04, 2008 | Remington HC-600 Hair Trimmer
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
12 people viewed this question
k24674
jasbo
jasbo
