Question about Garden
When the key is turned off or the kill switch is engaged the motor will not shut down
  • Bud H Jan 02, 2017
    Hi Wayne Pfeffer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 23 Answers
SOURCE: I have a 85hp Yamaha outboard motor. It starts
sounds like the ground wire in the control box where your key switch is located is broken are disconnected. check the wiring harness plugs if it is unpluged are not pluged tight it will not shut off
Posted on Jun 19, 2009
  • 257 Answers
SOURCE: Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Posted on Aug 12, 2009
  • 11 Answers
SOURCE: turn ignition key to lights and kills motor
faulty ignition switch...remove and test
Posted on Oct 01, 2009
  • 53 Answers
SOURCE: yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Posted on Nov 02, 2009
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
How can I shut off the motor? Is there a kill switch?
there is supposed to be a kill switch on side of engine. just follow the cable down to engine. it may be broke or just frozen. the cable that shuts down mower. Good-Day!
Jun 07, 2014 | Garden
Turn key and headlight comes on but wont turn over and have a new battery
Not to be silly but check your on/off kill switch... if it is in the ON it still may be in the switch... pull the clutch in Neutral safety switch is also in the circuit. Does it try to turn over? If you hear starter engage check starter solenoid or drive if the motor runs
Oct 26, 2013 | Harley Davidson FXST Softail Standard...
Husqvarna riding mower
The ignition switch takes the coil grounding wire to earth to cut the motor, so there is either a problem with the ignition switch or a break in the earth wire ( check the conections down by the engine ) to check the system run the machine with the deck engaged lift yourself out of the seat, if the engine stops it will be more than likly the ignition switch playing up, if it does not shut down there is a wiring issue.
Jun 20, 2012 | Husqvarna Garden
Motor shuts off when blades are engaged xmark zero trurn commerical
some of the switches work in series disconnect the kill switch wire from the engine and try it the work your way back to the switches
May 11, 2012 | Garden
My craftsman mower shuts off every time the blades are engaged. What is the problem?
you most likely have a shorted or open safety switch. you did not mention year or model # so I can only guess what configuration you have, but typically there are the following safety switches on a riding lawn mower: clutch/brake on switch (under floorboard at clutch, this allows you to get off the tractor with engine running if brake is applied), Reverse gear safety switch (will shut engine off if attempting to go in reverse with blades on...follow the gear handle rod down to transmission, may be internal or external of differential), there is also usually a disable switch to allow blade operation in Reverse and this is usually relay operated via a button or turn of the key position, Seat safety switch (under seat and usually is disabled via engaging the clutch/brake switch, this switch will kill the motor if you come off of the seat unless brake is applied), and of course a switch that is tied in to tell when blades are engaged (engage handle or PTO switch). It is actually simpler than it sounds and you dont' need to be an electrician to figure it out. start out with a visual inspection of the switches that you can see. I would suspect the transmission position (reverse) switch first, do you have an override? if so, turn it on and see if engine stays running with blades engaged. hope this helps and here is a link to a company that deals mower parts and has alot of great parts breakdown illustrations online. A craftsman is pretty much the same as a MTD or White Outdoor model, so look those up and it will show you the areas where switches are.
http://www.superxpower.com/pages/parts/viewbybrand/55/HusqvarnaPowerEquipment.aspx
Apr 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 2001 kawasaki 125 eliminator shuts off
If it dies when put into gear then its the side-stand switch (stand is down or switch not working)
If it dies when the clutch lever is released then either it was released too quickly with not enough revs, the engine doesnt have enough power to pull away or possibly the clutch switch is working in reverse
Good Luck
Hope this helps.
(If it does then please mark this as 'useful')
Ride Safe
Bike-Doc
Jan 29, 2010 | 2007 kawasaki Eliminator 125
Yamaha 115 will not shut off with key or kill switch
Sep 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Ignition trouble
the battery is drained. The kill switch only turns off the motor, while the lights and anything else that can continue to draw power will continue to do so till you turn the key off.
May 13, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
