Is there a service manual for the SPL-770M shredder?
I need to clean a thick accumulation of paper from the shredding drum.
5 Suggested Answers
geemarie
  • 876 Answers
SOURCE: SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Posted on Aug 01, 2008
JayBlair
  • 328 Answers
SOURCE: when on
Make sure there is no paper blocking the sensors. Otherwise you may have a bad sensor or switch.
Posted on Jun 05, 2009
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
SOURCE: staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Posted on Jan 08, 2010
How do I put Staples SPL-770M into automatic mode?
Turn it on and insert a piece of paper you want to shred.
Apr 21, 2015 | Staples Office Equipment & Supplies
How do I fix a staples spl tmc 10 paper shredder that does not feed?
It may be clogged with shredded paper. With power removed, examine the shredding mechanism and remove any bits you find. You may not be able to remove all of the bits but enough to restore operation.
Oct 09, 2014 | Office Equipment & Supplies
Staples shredder parts
You can try cleaning it and maybe limiting shredding to one sheet at a time.
Jan 14, 2014 | Office Equipment & Supplies
Staples Shredder SPL-S302D I think I need a new
Take a look underneath where the shredding mechanism is and remove every bit of paper. It is a messy job, but necessary. When you finish, the shredder probably will function normally. Also, ignore the advertised sheet capacity and feed one sheet at a time. Stop when the bin is half full, dump it, and repeat the bit-by-bit cleaning process. I just went thorough this exercise yesterday!
Feb 16, 2018 | Office Equipment & Supplies
Secure-Shred
Home paper shredders tend to accumulate bits of paper that have to be cleaned out from time to time. With power off, turn the shredding mechanism upside down and look for scraps or wadded up strips. Sometimes only tweezers and persistence will get rid of all.
Dec 18, 2012 | Shredder Secure Shred Shredder
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Staples SPL-770M shredder with overheat light even when cool
Sep 10, 2009 | Office Equipment & Supplies
When on
Jun 04, 2009 | Office Equipment & Supplies
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
SPL 1506X Shredder
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
144 people viewed this question
k24674
jasbo
jasbo
